Window Valet?
Old May 21, 2007 | 10:29 AM
XLR8BYU's Avatar
XLR8BYU
Default Window Valet?
I puchased my vette with this already installed and love it.
However, it has stopped working recently. Has any other user had this problem? Blown fuse? Connection?
I'm not exactly sure where it is located as it was already installed.
Any help is appreciated!
Old May 21, 2007 | 10:36 AM
JohnTheStigGalt's Avatar
JohnTheStigGalt
Never heard of this happening. It's installed in the OBD-II port in driver's footwell (if you stick your head far under the steering wheel and look up, you'll see it. It's about 3" long by mabe 1.5" wide. You should be able to just pull it right out. Maybe it's not seated all the way, which is why it isn't working...
Slade's Avatar
Slade
It is in the data port right under the steering wheel. You can just pop it out with your hand. There is a good possibility that it came somewhat loose.
Old May 21, 2007 | 10:49 AM
XLR8BYU's Avatar
XLR8BYU
Thanks for the responses, I'll check it out when I get home!
Old May 21, 2007 | 10:50 AM
oldschoolvette's Avatar
oldschoolvette
To Window Valet?
