My car is an 02 Coupe with only about 20k miles on it.
From my previous experiences my car batteries last for at least 8 years... . To my best knowledge the Vette still has the original battery (AC Crapco ). Two days ago it started cranking kind of "slowish".
Battery time? What is the expected life of a battery in a Vette?
If you're getting eight years out of stock batteries, you're having exceptional luck. Four or five years out of most factory batteries is pretty good usually. Of course it could be a lot of things, but I would have the battery checked first.
Easy enough to find out if it's your battery or not. Have it load tested, then you'll know. Since it's the orginal in your '02, good chance that it is. BTW mileage is not necessarily indicative of battery life. Tires more so, batteries not so much, time is more a factor for batteries.
I've never had a car battery last 8 years in any kind of car.
1996 Lincoln Mark VIII >Battery lasted until 2004 until the alternator failed.
1998 Ford Crown Victoria > Battery lasted until 2006... it was still at 50% when I decided to replace it.
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
If you're at 8 years on the orginal battery you're living on borrowed time. I'd replace it now before it does give up the ghost and leave you stranded somewhere.
As others have stated, 8 years is way long.
Get yours tested. You could try a battery tender to help with the slow starting and see if that helps. I got mine from Amazon.com for $45 shipped.
