[Z06] Quicksilver paint appears odd
Old May 22, 2007 | 10:15 AM
roll4speed's Avatar
roll4speed
Default Quicksilver paint appears odd
Looked at a 2001 QZ Z06 yesterday and when I pulled up and saw it the 1st thing I noticed was the paint was odd. The guy had cleaned it up and waxed it and the sun was shining on it. In the sun it looked kind of patchy (hard to describe) but not really noticable when cloudy. I guess it seemed that maybe the guy washed it too much. Can the clearcoat density cause this? He said he used Maguires and never any electric buffers. Low miles and garage kept but I noticed it in the sun and it drove me crazy. I noticed it seemed more obvious on the front bumper. It wasn't swirl marks or anything like that. Any clues?
Old May 22, 2007 | 10:34 AM
z06Bigbird's Avatar
z06Bigbird
Take it to a first rate body shop. They have a $500 laser tool that measures the thickness of paint. The used car mgr at my Caddy dealer uses one when estimating trade-ins.
Actually, you should call ahead. Not all shops have that tool.
Old May 22, 2007 | 12:31 PM
willseph's Avatar
willseph
I actually noticed the exact same thing on my QS Z06. It bright sunlight, the paint looks almost splotchy, thin in some spots, thicker in others. Mine is more prevalent on the front fenders. Sorry, I don't have any advice, just wanted to say I noticed the same thing.
Old May 22, 2007 | 12:33 PM
03 Z-oh-6's Avatar
03 Z-oh-6
From what I've heard, that's normal with QS.
Old May 22, 2007 | 12:57 PM
robdog289's Avatar
robdog289
Mine looks the same way. Original paint, probably just the way it is...
Old May 22, 2007 | 01:31 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
I have observed this “splotchy” appearance on prior Ford, Pontiac and now my 02 QS Z06. I shot something with “Galaxy Silver” from a spray can the other day and got a similar result. Seems to be a peculiarity of silver/gray/charcoal metal flake paint?
Old May 22, 2007 | 01:48 PM
hotwheels57's Avatar
hotwheels57
It might have been repainted at sometime, some metallics are hard to get consistent.
Old May 22, 2007 | 02:12 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Either a poor repaint or just the nature of a silver metallic paint.
Old May 22, 2007 | 02:25 PM
MiamiCowboy's Avatar
MiamiCowboy
I believe it just might be the properties of silver paint. I owned an 82 Vette that was silver and although beautiful it did have the tendency to cast odd shadows in the paint due to sun, clouds or body curvature. I own a black Z06 now but you face a whole different set of challenges with black.
On a side note I drove next to a silver 2007 Lexus 460 on Monday and I will tell you that was the finest quality paint on a production car I had ever seen. It was stunning and the tone and quality were exceptional. Later read that all Lexus 460 models are wet sanded by hand prior to delivery. This additional attention to detail definitely showed.
Old May 22, 2007 | 07:42 PM
stevedun's Avatar
stevedun
Cruise-In 8-9-10-12 Veteran
It does reflect sun different at times. Zaino nearly changed the color of mine. Took a lot of the grey color out. I like it. I don't think it is paint depth, but just the qualities of QS.
Old May 22, 2007 | 08:01 PM
JWB ZO6's Avatar
JWB ZO6
St. Jude Donor '06-'07
I have noticed that on QS vettes. I think it's common.
Old May 22, 2007 | 08:38 PM
stevedun's Avatar
stevedun
These pics were not in bright sun, but after Zaino. Wish I had better!
Old May 22, 2007 | 08:39 PM
zulatr's Avatar
zulatr
It is the metallic flecks laying differently within the paint.
This comes from varying wetness, and/or film thickness when the paint is sprayed. The metallic actually sinks in the paint and gives it a locally darker tint. It is fairly common on lesser repaints, and on OEM paint.
A good aftermarket full repaint would do away with that because the last coat before clear is sprayed very thin and dry, which lets the metallic flakes to stay right on top of the film. Cheap repaints and the OEM paint are done in as few coats as they can get away with to save $.
Whether it's OEM or a repaint, it's then it's covered with clear, and is not affected by waxing, washing, or polishing, unless someone rubbed right through the clear - not likely.
BTW- it's for this reason that silver is the hardest color to match. The paint can be off quite a bit (at least to a trained eye), just because of the way it's sprayed.
Old May 22, 2007 | 08:55 PM
BUBBAS 01Z06's Avatar
BUBBAS 01Z06
Same here on my QS Z !
Old May 22, 2007 | 11:40 PM
roll4speed's Avatar
roll4speed
Thanks for all your responses. I am not crazy. Some of you described what I saw exactly. I thinkit is different on every QS Z06 because I've seen some without the splotchy look in the sun. Would any of you not bought a car because of this anomaly with silver paint (on an otherwise good deal)?
Old May 23, 2007 | 12:10 AM
ptindall's Avatar
ptindall
Is this what we are talking about? Only sometimes in the sun, my fender has a different shade than the door. It's the only place I notice it and it only looks that way sometimes.
Old May 23, 2007 | 03:23 PM
jclarksnakes's Avatar
jclarksnakes
...I had the same problem with my sebring silver SS Camaro. After Zaino coats it would look great until you started comparing surfaces. I think zulatr has described the how and why of the problem.
Jeff
To Quicksilver paint appears odd
Old May 23, 2007 | 03:30 PM
bill mcdonald's Avatar
bill mcdonald
I noticed this on my 01 as well.
there is a bizzare line that shows up on the hood and runs on to the cowl. It looks like someone painted an odd circle there. when overcast I cant find the line. When it is in direct sunlight I see it no problem.
Old May 23, 2007 | 04:10 PM
BonestockZ06's Avatar
BonestockZ06
Mine too, I looked everywhere under the sun looking for signs of repairs or re-paint, but nothing. I see the same blotches unders the sun and it was driving me crazy because I thought I bought a z thats been crashed before. I'm the second owner, clean carfax. It may just be the paint, I've learned to live with it.
Old May 24, 2007 | 01:07 AM
geterdone's Avatar
geterdone
Same here, some of my friends tried to tell me that my car had been wrecked.
