Headlight issue/Need help
Old May 22, 2007 | 02:14 PM
Slowvette002's Avatar
Slowvette002
Default Headlight issue/Need help
Ok, so awhile back my drivers side headlight started going down and then popping back up when shut off. I would have to get out and manually lower it by hand. After asking some ppl on here, one person said it was probably the tabs that were shot and would have to be replaced. After reading that I went out and checked to see if this was the problem. Sure enough, one of the tabs on the inside was shot. To make sure that was the problem I took one off my other headlight(that was in good condition), and put it on the broken one. Turned off the headlights, and it worked perfect. Well, I had to put the good one back on the side it was supposed to be on, and now I have checked all the local cheverolet dealerships, and no ne of them can find the tabs in thier system. Does anyone have a part # for these. I even took the old tab in, had him breakdown the entire headlight assembly on the computer, and they just cant seem to find where the tabs are in the system to order. Does anyone A.) know a way or part # that can help me get these guys to find them, B.) have any extra tabs that you would be willing to sell?
Any help is greatly appreciated. Thanks ahead of time guys
Old May 22, 2007 | 02:35 PM
02MillenniumVette's Avatar
02MillenniumVette
I dont know what the part # would be but PM Gene Culley, he should be able to help you out. Here is his website also.
www.gmpartshouse.com
Old Dec 12, 2007 | 11:09 AM
Kale's Avatar
Kale
Cant find it on his site...
Old Dec 12, 2007 | 11:47 AM
Oldvetter's Avatar
Oldvetter
Theres a TSB out for that problem. Its an easy fix:
Number: 00-08-42-002
Subject: Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators)
Model Year: 2000 Chevrolet Corvette
Condition
Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly.
Correction
Important
The following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on the right front headlamp door motor/actuator.
Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual.
Parts Information
Part Number Description Qty Per Vehicle
11505463 Washer 3
16524060 Insulator 2
(Post copied from DeeGee)
Old Dec 12, 2007 | 08:28 PM
Kale's Avatar
Kale
Right... but some people have the issue because the tabs are broken. 2 second fix with the tabs... but no one seems to be able to come up with a part number.
Old Dec 12, 2007 | 09:16 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Originally Posted by Oldvetter
Parts Information
11505463 Washer 3
Part Number: 16524060
List Price Core Price Your Price
INSULATOR
$6.00 $0.00 $4.57
To Headlight issue/Need help
