remove key for 10 sec
Old May 25, 2007 | 08:35 AM
floyd66's Avatar
floyd66
Default remove key for 10 sec
I have a 2002 z06 20,000 miles. Dealer installed k harness at 18,000 miles. With the key out the wheel turns.
Yesterday I started the car went to move & it stalled. The dic said remove key for 10 sec I did & it started & ran good.
Anyone have this problem? Don't want to get stuck on the road.
Thanks Floyd
Old May 25, 2007 | 10:00 AM
DeeGee's Avatar
DeeGee
Sorry to say I think you may be the latest victim of the screwed up GM column lock mod.
Not sure if a CLB will solve your problem at this stage.
I cant belive GM cant get that fix right.
Best take it back to the stealership and see if they can unfix it.
Old May 25, 2007 | 02:03 PM
WWK888's Avatar
WWK888
http://forums.corvetteforum.com/show....php?t=1714118
Old May 25, 2007 | 02:07 PM
Bill Vett's Avatar
Bill Vett
First try cleaning the resistor on the key with some alcohol and see if it helps. it's not always a column lock problem.
Old May 25, 2007 | 02:56 PM
LeeJones's Avatar
LeeJones
From: I saw her today at the reception.....a glass of wine in her hand...
Old May 25, 2007 | 03:08 PM
Tom/99's Avatar
Tom/99
I've seen that fix, on more than one C5.
Old May 25, 2007 | 04:46 PM
DeeGee's Avatar
DeeGee
I'd believe that if he hadn't just had the GM column lock fix done
Old May 25, 2007 | 05:45 PM
floyd66's Avatar
floyd66
Default Thanks
I cleaned the key I'll see what happens.
Old Jun 1, 2007 | 05:25 PM
LeeJones's Avatar
LeeJones
any updates?
To remove key for 10 sec
