How Long Will A Vert Top Last?
Old May 26, 2007 | 11:43 PM
TexasMadMan's Avatar
TexasMadMan
Default How Long Will A Vert Top Last?
Another thread got me curious. How long can you expect a vert top to last if the car is parked in a garage and exposed to sunlight about 5000 miles a year? The top has been treated with protectant. I know this is not science, but any guesses?
Old May 26, 2007 | 11:47 PM
GS Ron's Avatar
GS Ron
Mine is 9 years old and no problems
Old May 26, 2007 | 11:51 PM
BATM4N's Avatar
BATM4N
You can expect to get 8-10 years The top will still look good after this time but time will take it's toll of constant stretching of the material and will start to rub on the window when you close the door and there is only so much you can stretch it before you'll need a new one.
Old May 26, 2007 | 11:53 PM
TexasMadMan
Thanks for the answers. Anyone else?
Old May 26, 2007 | 11:54 PM
NOS500's Avatar
NOS500
Id say they make it 7-9 years.
Old May 26, 2007 | 11:58 PM
GS Ron's Avatar
GS Ron
Rub on the window???????????
Old May 27, 2007 | 02:08 AM
DeeGee's Avatar
DeeGee
My 02 has lived in the Vegas sun for 3 years. Its always garaged. I give it a clean every 6 months or so and treat it with protectorant. Cleaned it yesterday and it still looks like new.
Old May 27, 2007 | 03:16 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
My '95 is still in great shape...the '04 is like new...if you use Wolfsteins "Raggtopp" it should last for a decade or two depending how much outdoors it sees
Old May 27, 2007 | 03:20 AM
DeeGee's Avatar
DeeGee
Originally Posted by Yello95
My '95 is still in great shape...the '04 is like new...if you use Wolfsteins "Taggtop" it should last for a decade or two depending how much outdoors it sees
Would that be Ragg Top
Old May 27, 2007 | 03:29 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
...no sir...it would actually be>>>
RAGGTOPP Fabric Protectant
Funny how the R would be right next to the T on the keyboard ...and yes...its 2 P's
Old May 27, 2007 | 04:21 PM
BATM4N's Avatar
BATM4N
I got a chance to talk to the guy who installed my new top this year. He's been installing convertible tops for 18 years and said years of constant stretching to keep it tight combined with sun exposure takes it toll on the material. He said on the vettes he sees the top stretch over the right or upper corner of the door to the point where it starts to wear but they last longer than most the other vert tops on other cars. This can be adjusted only so many times before its time for a new top.
With my new top, I now allow it a chance to relax by raising the top when I know I'm not going to drive it for 2 or more days. As someone also mentioned on another thread, it also gives the rubber window seals a chance to relax.
Old May 27, 2007 | 06:57 PM
GS Ron's Avatar
GS Ron
I used to do that with a 65 Vert that I had and the guy that installed the top said, that was the worst thing to do. That it was best to keep it up and latched when not using it...........
Different advice sure is confusing
Old May 27, 2007 | 07:08 PM
WvCorvette's Avatar
WvCorvette
Old May 27, 2007 | 09:33 PM
krm_wi_C5's Avatar
krm_wi_C5
I have a '98 vert, top is original and still looks very good. Mine is in the garage most of the time, never sits out in the sun. I usually drive it with the top down. I always have the top up and latched in the garage. Seems to work for me.
Old May 28, 2007 | 01:01 AM
BATM4N's Avatar
BATM4N
When mine was replaced months ago, it also looked brand new. It looked so good the bodyshop told me I would get full credit for a replacement. Apparently, they pro rate it based on how new it looks but you could see in the top right corner where at one time it had rubbed against the window exposing the wire along the seam.
Before it was replaced, there were times when it seemed as if you could hear a slight ripping sound when I was driving but maybe it was my imagination. I'm the second owner, but was told it was mostly driven to work and then garaged when at home. I think you could probably stretch it(no pun intended) to 11 maybe 12 years under the best of conditions but it depends on what your definition of "last" is. I think you could get 15-16 years out of it but would look like
Old May 28, 2007 | 09:50 AM
Vector's Avatar
Vector
I replaced the black top on my 1998 last year. Car is a weekend cruiser (5K per year - 95% top down), rarely sees rain and is garaged and covered most of it's life. Cleaned annually with RaggTopp. Top was still good/functional but had shining wear marks behind both side windows. No tears or frayed areas just didn't look good. Tried lots of stuff to bring them back but to no avail. So, depending on how picky you are will best determine how long your top lasts. Mine made 8 years with lite useage - less picky, it would still be in use!
To How Long Will A Vert Top Last?
