Headlight motor won’t stop running. Help!
Old May 27, 2007 | 09:06 PM
Robert Potter's Avatar
Robert Potter
Default Headlight motor won’t stop running. Help!
The driver’s side headlight motor continues to run approximately 5 seconds after it is retracted into the body??? I can hear the nylon gears grinding until it stops. Is there an adjustment for the “cut off switch”? The passenger side works fine.
Old May 27, 2007 | 10:05 PM
cortex's Avatar
cortex
Ah, stripped gear.
Here you go:
http://www.bfranker.badz28.com/headl...earinstall.htm
That's for a Camaro but it's about the same for the vette.
Many here will tell you upgrade to the brass gear. That's ok, but I am on year 5 of the free fix (flipping the nylon gear over) and still going, even with the heavy Euro lights.
Old May 27, 2007 | 10:56 PM
DeeGee's Avatar
DeeGee
Run down to headlight gears in this sticky. It'll give you full instructions on how to fit the replacement brass gears. f you're going to do the job you may as well fit a gear that will last IMHO
http://forums.corvetteforum.com/showthread.php?t=984927
Old May 27, 2007 | 11:11 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
It's not a horrible job, But I would (and did) use the brass aftermarket gear. As I'm glad I only had to do this job ONCE per side.
Old May 28, 2007 | 11:39 PM
ninjazed's Avatar
ninjazed
My 2 cents:
The Franker gear is nice but I opted for the brass gear kit from Rodney Dickman. His gear follows the factory design with a new beefy rubber bushing and also includes a new brace that takes stress off the plastic assembly after it's glued back together.
It seems like a daunting task and took me over three hours just for one side cause I really took my time. I was very satisfied with the results and am now confident that this gear will probably last me the life of my 2002 coupe.
Old May 29, 2007 | 03:57 AM
zTrek's Avatar
zTrek
Originally Posted by ninjazed
My 2 cents:
I replaced mine with Rodney Dickman gears and couldn't be happier!
To Headlight motor won’t stop running. Help!
