[Z06] Z06 Weekend :)
Old May 28, 2007 | 01:38 AM
TType85's Avatar
TType85
Default Z06 Weekend :)
I've had my 2001 Z06 for 2 weeks now. I decided I wanted to do a bit of maintinance since it is at 44K miles and I don't know when the previous owner did it last.
Done:
  • Sway bars: bushings greased
  • Tires: New Firestone Wide Ovals in stock sizes. Car will be street driven 99% of the time.
  • Oil: 7qt of Amsoil 5w30 and Amsoil filter
  • Transmission: ~4qt of Royal Purple Synthetic ATF (Dexron III)
To Do:
  • Rear end: Either Amsoil or Royal Purple
  • Coolant: ??? -- Need to look up
  • Clutch fluid: going to do Rangers method
  • Brake Fluid: ??? -- Need to look up
Anything else I am missing maintinance wise? Hoses and belts look good. Brakes are at about 80%. I am going to seafoam before the next oil change. The car runs great and I am more impressed with it every day.
Tomorrow, it will get a good bath. I need to have the car buffed out though, black + swirl marks =
Old May 28, 2007 | 11:31 AM
96cobrakid's Avatar
96cobrakid
clean out between the rad. and ac condensor. i bet there is all kinds of debris up there.
Old May 28, 2007 | 12:12 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Other than what you did I would do a top end clean before you changed the oil and installed a catch can right after. Also don't forget the fuel filter.
Old May 28, 2007 | 02:35 PM
floyd66's Avatar
floyd66
Did the trans. shift better after the fluid change ?
Just wondering
Old May 28, 2007 | 03:58 PM
TType85's Avatar
TType85
Just wondering
It seems a bit smoother. I think it was worth it.
Checked it out and it was clean.
I'll get a fuel filter this week. Who has the best catch can? I think I will clean the TB too.
To Z06 Weekend :)
