Rubber A/C line protector
Old Jun 7, 2007 | 11:09 PM
jdmvette's Avatar
jdmvette
Night Owl for life
i don't have one on my y2k.
Old Jun 7, 2007 | 11:28 PM
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
My 2001 has that piece... just checked .
Old Jun 8, 2007 | 07:45 AM
Vettman 1's Avatar
Vettman 1
My 2000 doesn't have it, but there's about 1/2" clearance between the aluminum tubing and the edge of the radiator shroud.
Old Jun 8, 2007 | 08:24 AM
Patches's Avatar
Patches
Wow! Didn't mean to start trouble by posting this.
I would just cut a piece of tubing of the appropriate diameter and length, slit it lengthwise and place it over the A/C line. Not worth the hassle of dealing with parts departments without a clue.
Oh, and both my '02's have this part intact.
Best of luck!
Old Jun 10, 2007 | 07:14 PM
H-T's Avatar
H-T
I ended up using about a 3-inch length of clear plastic flexible tubing and slitting it open and placing it over the small radiator hose that is being cut by the shroud. I was able to slightly bend the aluminum a/c line so it is lower now. Should be safe now.
Old Jun 10, 2007 | 09:53 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
This is the way to go, these darn things fall out so easily without pressure against them,it sorta useless..........IMO
Something is fishy with GM parts. I stopped in at the stealership today to check the truthfulness of what GMpartsdirect.com told me. I had the parts counter man pull the upper radiator shroud off his shelf. Still sealed in thick clear plastic. There is no rubber insulator for the a/c line with that $100 part. Yes my local dealer really wanted $100 when GMpartsdirect is asking half that. Not only does the factory have a quality control problem, but their OEM parts are also as inconsistent as their prices. GM still insists that the only way to get that rubber part is to buy GM PART #10405439. Sight unseen, I cannot trust GM to buy over the Internet. I love this car for the HP, but I really hate the quality control problems. No wonder GM is in financial trouble again.
I just ordered the upper radiator mount from gm parts direct( Gene) and that lil' bugger was rolling around in that big plastic bag
