Engine missing a beat!
Old May 29, 2007 | 09:10 AM
Apache One's Avatar
Apache One
5th Gear
Default Engine missing a beat!
This morning, I pulled up behind a Nissan 240, obviously hopped up, had a bunch of performance stickers, dumb exhaust. I thought I would have a little fun. The light changed, he gunned it and I ran with him. As I moved into the other lane to pass him, my engine slightly cut out in 1st gear as well as second gear (6spd). Like it missed a beat in both gears. Rear end was slipping a little, trac control was on. Car was still a little cold, about 163 degrees (coolant temp), just leaving the house. This is the first time this has ever done this, have anyone experienced anything like this? Do you think the traction control would cut power to prevent slippage? Only mods are a Vortec Rammer and aftermarket exhaust. I will give the Nissan credit, it was pretty quick. If it were not for the engine cutting out, I would have surely blown his doors off. We only got to 3rd gear and then the light changed and went our separate ways. He was still behind! The rest of the drive in on the highway was no problem. Any thoughts?
Old May 29, 2007 | 09:34 AM
LMB-Z's Avatar
LMB-Z
Ibtl
Old May 29, 2007 | 09:37 AM
Z06HPISFUN's Avatar
Z06HPISFUN
St. Jude Donor '07
hit the rev llmiter.......
ib4tl
Old May 29, 2007 | 09:58 AM
Apache One's Avatar
Apache One
5th Gear
ib4tl, sorry not sure what that means.
Reve Limiter?
It was on acceleration when the problem happened, not at the top of the revs.
Again, this has never happened. i would not think anything of it if it happened in only one gear, but both 1st and 2nd was a little concerning.
Old May 29, 2007 | 10:06 AM
1-BAD-C5's Avatar
1-BAD-C5
traction control cuts power to the rear wheels if you spin... dont worry about it its normal,.. next time just turn traction control off and have fun
Old May 29, 2007 | 10:07 AM
yellow01's Avatar
yellow01
Uh, well, that's why it's there...
and no street racing.
Old May 29, 2007 | 10:22 AM
Apache One's Avatar
Apache One
5th Gear
I will close the case then. Thanks for the help.
Old May 29, 2007 | 01:38 PM
bonnell's Avatar
bonnell
Hi Apache One,
ib4tl means in before the lock. This forum locks threads describing street racing. We all know what its like to want to have some fun but street racing is dangerous to others on the road so it is a taboo subject here.
The moderators will lock the thread if street racing is discussed.
I'm glad everything turned out ok.
J
To Engine missing a beat!
