Battery replacement
Old May 29, 2007 | 03:23 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Default Battery replacement
Replacing my batt. Anything special I have to do after installing?
Old May 29, 2007 | 03:33 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
When you disconnect battery sometimes have to reprogram key fobs. Don't know if you have memory option and whether that needs to be reset also. Owners manual has instructions for training key fobs.
Can also do a search of forum and find instructions as they have been posted several times of late.
Old May 29, 2007 | 03:38 PM
my6thvette's Avatar
my6thvette
Usually all you have to do is hold down the lock and unlock buttons on the key fob until the horn beeps. Then you are good to go.
Old May 29, 2007 | 03:41 PM
Benpup's Avatar
Benpup
Thank you!!!!!!!!!!!
Old May 29, 2007 | 03:50 PM
WWK888's Avatar
WWK888
Hope you have your theft code for your radio or disable it before you disconnect.
Old May 29, 2007 | 04:27 PM
Patman's Avatar
Patman
It's not that simple, you need to reprogram them via your DIC. At least that is the case on my 98.
Old May 29, 2007 | 04:59 PM
LoneStarFRC's Avatar
LoneStarFRC
Juuuuust in case.
Old May 29, 2007 | 05:19 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Originally Posted by LoneStarFRC
Juuuuust in case.
also. If a previous owner has activated the Theftloc and you don't have the code, it's a pain to unlock but it can be done, without a dealer's help, I might add.
To Battery replacement
