[Z06] Clutch or what?
Old Jun 1, 2007 | 03:49 PM
DPG's Avatar
DPG
St. Jude Donor '06
Default Clutch or what?
Ok I've got an 01Z with 41,000miles stock clutch with the new 07Z06 shifter and ****. Here is my issue that just came up today actually
When I'm in first and the clutch is starting to engage, sometimes there will be a slight chatter. Not always but every 4-5 times. I also get it shifting into 3rd or when I downshift into 3rd i will get that chatter. Also, I am starting to miss 3rd every once in a while. either in a downshift or upshift. Thats like every 10 times or so. Whats goin on here? Thanks for any help in advance
Dave
Old Jun 1, 2007 | 04:01 PM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
I would start with a fluid change on the transmission first and go from there. Depending on your driving style is what willl determine if you need to change it or not but if it is not slipping then look elsewhere.
Old Jun 1, 2007 | 04:02 PM
DPG's Avatar
DPG
St. Jude Donor '06
I changed the fluid last year along with the diff fluid to mobil1. I don't think the clutch is slipping.
Old Jun 1, 2007 | 04:10 PM
stingray454's Avatar
stingray454
If you haven't changed the clutch material, clutch chatter is usually caused by a warped flywheel or pressure plate, or oil on the clutch.
Old Jun 1, 2007 | 04:28 PM
Road machine's Avatar
Road machine
Before you do anything major, I would pull the return spring. It could be the peddle feel that is causing trouble. If it works then leave it out, mine has been out for over a year. If it doesn't help just put it back in. This should take less than 10 minutes to take out and put back.
Old Jun 1, 2007 | 07:14 PM
The Clutch's Avatar
The Clutch
I say what.
Old Jun 1, 2007 | 07:49 PM
DPG's Avatar
DPG
St. Jude Donor '06
I hope this isn't it.
I already pulled the spring when I had the sticky clutch pedal last year.
Thanks for the advice so far guys, keeps the thoughts flowing.
Old Jun 3, 2007 | 03:04 PM
DPG's Avatar
DPG
St. Jude Donor '06
ok im starting to narrow it down to syncros. I dont get it in every gear and it doesn't happen all the time. Shifting into 3rd it wont let me sometimes and a split second later it will go into gear. Guess its dealer time Still got the warranty luckily
Old Jun 3, 2007 | 10:19 PM
VetteTech81's Avatar
VetteTech81
Let us know what they find..
-=Rick
Old Jun 3, 2007 | 10:24 PM
jclarksnakes's Avatar
jclarksnakes
I would not rule out a clutch problem yet. It could be surfaces that are not bedded in well yet or a warped or glazed flywheel or as was mentioned earlier oil or grease on the surfaces from the installation.
Good luck,
Jeff
Old Jun 4, 2007 | 01:56 PM
Z06Fix's Avatar
Z06Fix
What is this about a return spring? Where is it and what do you gain by removing it?
Old Jun 4, 2007 | 04:46 PM
DPG's Avatar
DPG
St. Jude Donor '06
I'll let you know what Kevin at libertyville says Rick.
The return spring is on the clutch pedal. And its supposed to make it easier to push the clutch pedal in. It was one of the recommended aides to help fix a sticky clutch pedal. It helped a little bit when I did it a yr ago, but changing the clutch fluid was a much better fix.
I still haven't ruled out a clutch yet, but as the problem keeps getting worse, i am thinking syncros more and more. one of the symptoms is it makes the same sound when going into gear even before i start to release the clutch pedal. So i don't know if the clutch isnt disengaging all the way or what. But It doesn't smell like clutch unless all the clutch material is gone and thats why you can't smell it
Thanks for the suggestions and ideas guys, but as this problem is getting worse quickly, I have thrown in the towel and am taking it to Kevin before i break down
Old Jun 4, 2007 | 06:24 PM
VetteTech81
Kevin is a good guy, he will take good care of it!
-=Rick
Old Jun 4, 2007 | 10:14 PM
perfectlyfrank's Avatar
perfectlyfrank
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Cruise-In 8, 9 & 11 Veteran
-=Rick
If there is anyway the work can be done under warranty, Kevin will take care of you. We are very lucky to have such a meticulous and honest dealer tech in our area. My GMPP has paid for itself 3x over.
Old Jun 5, 2007 | 10:41 AM
DPG's Avatar
DPG
St. Jude Donor '06
well after the test drive they think its "a pilot bearing or the release bearing" I had to authorize them to take the trans out and as of now if the warranty company doesnt cover it, im eating the costs Find out later today what is going on im sure and tomorrow to see if the warranty company will cover it.
Old Jun 5, 2007 | 10:46 AM
perfectlyfrank
Sorry to hear that Dave. That really sucks!
Old Jun 5, 2007 | 12:36 PM
DPG's Avatar
DPG
St. Jude Donor '06
what are you gonna do. Its gotta get fixed anyhow.
To Clutch or what?
Old Jun 5, 2007 | 03:19 PM
dbirdz06's Avatar
dbirdz06
I'm curious to know the outcome, please keep us posted
Old Jun 5, 2007 | 03:33 PM
DPG's Avatar
DPG
St. Jude Donor '06
sure will
Old Jun 6, 2007 | 12:43 PM
DPG's Avatar
DPG
St. Jude Donor '06
ok so far its a pilot bearing and an input shaft. and a BIG ? whether my extended warranty company covers it They are putting an estimate together right now for the warranty company
