C5 clearcoat is insane
Old Jun 2, 2007 | 01:37 AM
Chicago's Avatar
Chicago
St. Jude Donor '15
Default C5 clearcoat is insane
I know the waxers out there hate the clearcoat on the C5. It's rock hard, yet scratches very easily (how did GM come up with that?) Anyway, I've tried many compound and pad combos to try to correct mine. I've finally found the winning, albeit time consuming combo. Here's a couple of before after shots. It was getting late so I'll finish up tomorrow:
before
after
before
after
Process used:
Menzerna IP with Lake Country purple wool/foam pad @1500rpm (x2)
Menzerna FPII with 3M white compound pad@1500 rpm (x2)
Old Jun 2, 2007 | 01:40 AM
always717's Avatar
always717
big difference, but how can you tell if the swirling is in the wax or in the clearcoat, without compounding?
RLYSLO's Avatar
RLYSLO
St. Jude Donor '08
awesome work!
Old Jun 2, 2007 | 01:44 AM
Chicago's Avatar
Chicago
St. Jude Donor '15
Probably the easiest way is to get a claybar kit and use it to remove any bonded surface stuff. Then clean with some detail spray you'll know right away if the swirls are in the clear or in the wax.
Yello95's Avatar
Yello95
St. Jude Donor '11
Old Jun 2, 2007 | 02:15 AM
SebringSixSpeed's Avatar
SebringSixSpeed
That looks amazing. I just sold my black Dodge dually and swore I'd never own another black vehicle (because of the swirls), but I might reconsider now.
Old Jun 2, 2007 | 03:48 AM
Dave1's Avatar
Dave1
St. Jude Donor '09
Very good paint correction.....
Your right, C5 and C6 cc is rock hard. The Menzerna twins win again....
Old Jun 2, 2007 | 06:45 AM
steve8's Avatar
steve8
It's amazing what you can do with a rotary if you know what you are doing.
Old Jun 2, 2007 | 06:50 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Awesome results.
Old Jun 2, 2007 | 06:57 AM
Black C5 LS1's Avatar
Black C5 LS1
Very true.... and that's a very big "if"! I wouldn't trust myself doing it, and I'd have to see similar results beforehand from somebody else I'd trust to do it. I've been burned too many times from those who have made similar claims and haven't delivered the goods. It's all easier said than done. The "after's" look like Chicago taking pictures in a mirror! Very impressive.
(root beer)
John
Old Jun 2, 2007 | 10:08 AM
berryj's Avatar
berryj
I used the Menzerna IP and FP on my vette trunk lid and my wife's BMW to remove a lot of haze from a prior polish job. It was the only stuff that would work after trying lots of swirl mark remover etc. I used my Porter Cable plus the orange pad. Worked great, although most insist on a rotary rather than my random orbital buffer. I'm too chicken to use a heavy duty rotary!
Old Jun 2, 2007 | 10:12 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Old Jun 2, 2007 | 05:47 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
I was also leery about running a rotary across my car. But after many, many tries with the PC & IP/orange pad combo I wasn't getting anywhere. Since the clear is so hard, it's very forgiving. You just have to be patient with it. The Lake Country purple pad is terrific for clearing up a good chunk of the swirls. Followed by a white pad it takes care of the holograms that are commonplace with a rotary. I'm almost done! This takes way too long.
Old Jun 3, 2007 | 09:28 AM
berryj's Avatar
berryj
Thx for the tips. I'll consider it in the future.
Old Jun 3, 2007 | 10:06 AM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
I have the PC, and the Menzerna products too. I also was hesitant to use a rotary, so I stuck with the random orbital. The results were good, but I might have to do it again, and just spend a little more time on it. Good lighting is a MUST for this stuff. I just worked outside, and when I saw the car in different lighting, alot of stuff showed up. to the Menzerna products though to remove these paint flaws. By the way, why did you only work at 1500 rpm's. Is that the normal rpm for a rotary? I worked at 3000- 4500rpms, which is what they recommend for a random orbital.
Old Jun 3, 2007 | 10:13 AM
jrose7004's Avatar
jrose7004
Excellent results!
Old Jun 3, 2007 | 01:16 PM
Busarider's Avatar
Busarider
Good work.
For the guys leary of the Rotary, with foam pads they are pretty forgiving. Not like back when wool was the only choice. You also might want to give a Cyclo a look. It's very much like using the PC.
To C5 clearcoat is insane
Old Jun 3, 2007 | 04:03 PM
GTC's Avatar
GTC
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05
Nice. Very nice. I've always done my waxing by hand, but I might have to pick up one of these soon.
Old Jun 3, 2007 | 05:05 PM
waddisme's Avatar
waddisme
I just got my TR Z06 2 weeks ago. I spent 6 hrs yesterday with pc @ 5500 rpms, Lake Country yellow pads, and 3M medium cut compound with 2 -3 passes. Although I got all the blemishes and swirls out, there are still scratches that just won't go ! I have the Menzerna IP, but when I did the paint on the TA, the 3M seemed to work a little better. I will try the IP but i don't hold much hope for it. Is the rotary the next step before I try wet sanding? These are not major scratches, but just the kind from improper washing, but they will not come out!
Old Jun 3, 2007 | 05:48 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
OUTSTANDING!
C L
