oil ques
Jun 2, 2007 | 09:28 PM
oil ques
can I mix penzoil synthetic with mobil one? Im a quart low and the local places only had this avail.!
Jun 2, 2007 | 11:23 PM
Jun 3, 2007 | 02:16 AM
St. Jude Donor '11
Quote:
Originally Posted by
racer847
I do not think it will hurt a thing to mix it with Mobil 1 (synthetic)
Jun 3, 2007 | 02:22 AM
You should be fine.
Jun 3, 2007 | 02:23 AM
St. Jude Donor '11
JDs00PewterCoupe
You should be fine.
JD has spoken
Jun 3, 2007 | 07:52 AM
Just in case you did not know, penzoil synthetic IS on the list of approved and tested oils for the C5 and yes it can be mixed with Mobil 1.
Jun 4, 2007 | 01:51 AM
Jun 4, 2007 | 02:29 AM
yeah its fine there are only slight differences.
Jun 4, 2007 | 07:57 AM
A a rule of thumb , in a perfect world it is best not to mix oils of different weights, types, and manufacturers, because the differrence in additive chemistry is a slight number of times could cause additive drop out.
However, additive manufacturers know this and blend their formulations to ensure this almost never happens.
Just remember one oil is better than a mixture of two..
and ANY oil is better than NO oil
