[Z06] Service Active Handling?
Old Jun 4, 2007 | 08:20 AM
tx_zo6's Avatar
tx_zo6
Default Service Active Handling?
Anyone Know How To Correct This Code? Every So Often My Car Will Flag The "service Active Handling" For No Apparent Reason. Bad Ground? ****ty Connection? Any Help Would Be Cool.
Old Jun 4, 2007 | 10:50 AM
yellow 02 Z06's Avatar
yellow 02 Z06
its most likely something electrical. mine throws the service abs/active handling/tcs code sometimes when i roll the windows down. Weird. The lights dim right when it happens and also it does it at the exact same geographical location every time if i roll them down. so yes its probably a bad connection or the like. i beginning to think my wiring is just possessed.
Old Jun 4, 2007 | 11:09 AM
Vegas Vette's Avatar
Vegas Vette
Your EBCS Modual is going bad its is a pretty comon. Do a search and you will find alot of post about this problem.
Old Jun 4, 2007 | 11:59 AM
CleteZ16's Avatar
CleteZ16
St. Jude Donor '09
Mine displayed the same message after doing donuts (in a controlled, legal environment ) .. I thought I'd broken something til I came home, searched the forums, and discovered I'd just pegged the yaw sensor. Cleared the code and no problems since.
Search the forum for "clear codes" or "display codes" ..
If it hadn't been for this forum, I would have gone to the dealer and been out at least a hundred bucks I'm sure.
Try here:
https://www.corvetteforum.com/techti...D=26&TopicID=1
Old Jun 4, 2007 | 12:41 PM
txz06ce's Avatar
txz06ce
I just got my 2004 Z06 back from the dealer after having the same message and codes. It's still under warranty and they replaced the EBCM.
Old Jun 4, 2007 | 12:45 PM
straatien's Avatar
straatien
As previously stated, the EBCM could be going bad. I did the research herein when it first started on my 2002 Z06 and now it is always on. I've ignored it for many weeks and to spite me the car now periodically tells me the ABS is also on the fritz. I hope I did not bring this on by installing a 150 AMP alternator to resolve "dimming" issues. I understand that replacing the EBCM via dealership can cost approximately $800.00 USD.
Since the AH/TC doesn't work I am now at the same disadvantage as the Viper drivers are when they drive their cars off the lot.
Old Jun 4, 2007 | 03:28 PM
yellow 02 Z06
$800 Thank god my car is under warranty
Old Jun 4, 2007 | 04:21 PM
RedLS1GTO's Avatar
RedLS1GTO
Search: EBCM
If that doesn't work, you might consider searching for "Stupid part that Chevrolet threw into the Corvette that isn't worth a sh*t that breaks on a HUGE number of our cars and costs a buttload to fix."
Hope that helped.
Old Jun 4, 2007 | 05:21 PM
TM-Z06's Avatar
TM-Z06
ABSFixer.com is the solution if your car is not under warranty. Much less expensive than the stealership, and more reliable.
I'll be sending mine soon
To Service Active Handling?
