One of the major factors in the top speed of a C5 is the wall of air that the car ends up pushing when it gets up to ~175 mph, and I am sure that the same air reduces acceleration to some extent all the way up. Anyone have any ideas of how to reduce the air build up in front of the car.
You could try taping over the brake vents and partially over the intake with some 200 mph tape. The NASCAR guys do this. It may be worth one or two m.p.h.
Reason: wrong
The major factor in the C5's 175 mph top speed (171 mph for the Z06) is you are at redline in 5th gear at that speed. Reducing drag won't change the top speed in 5th. You'd have to reduce an ENORMOUS amount of drag to get a stock C5 to get much past 150 mph in 6th gear.
Reducing drag would help the car reach its top speed sooner, but it is a long slog to 170+ mph, and I'm not aware of many places you can LEGALLY get the car to that speed. Most race courses just don't have enough straightaway to get anywhere near the car's top speed.
Maybe if you join something like the Silver State Classic you can reach the car's top speed .... http://www.sscc.us/
You are correct that there is not too many places that have enough room to get the car up to max speed. However, i grew up in the back woods of Elberta, Al and when I had the car down there for my wedding in April, i had the car up to 160 and still had about 2 miles of straight road before I had to start stopping. But thanks for the link. Sounds like a lot of fun.
"Race cars capable of going 200 mph usually have at least 650 hp, about 350 of which goes into overcoming air resistance. It is probably possible to go 200 mph with a car in the 450-500 hp range, but such a car would have very good aerodynamics; expensive, low-friction internal parts; and low rolling resistance tires, which are designed to have the smallest possible contact patch like high performance bicycle tires, and are therefore not good for handling."
If you haven't already, lowering the car with the front lower than the rear will help by keeping air from going under the car. You could also cover any holes such as the brake ducts and front grill areas. These ideas will also increase stability at such speeds.
The faster you go, the more the air drag reduces the rate of acceleration to a huge degree. The HP required to overcome air drag increases as the cube of speed, so if a vehicle is trying to accelerate well on the top end, it needs huge amouts of HP up and beyond what's required to hold constant high speed. At high speed (180 mph), it will take about 6~7 more RWHP to gain 1 more MPH with a C5 Vette.
very impressive video. I am in Germany and my wife and I coming home from work both hit 175MPH, easily, hers is an 02 Z06 and mine an 01 with 04 LS6 long block. My fastest is 187 in a nice down 7 kilometer downward slope after hitting 183 or so in 5th first and then 6th.
The biggest problem is I hit that damn fuel cutoff like a brick wall at 183 in 5th, I still have pedal to go. 60-75mph seems like I am riding a bike to me now. I also track my car at Hockenheim and well it all looks like a giant race track to me on the autobahn.
ciao,
californiakid
MCM hood is extraction design according to their people it really works. I just like the way it looks on the car. Anyways is supposed to adress the air build up.
Just go F/I & utilize that 6th gear! All you would have to worry about is the lift at 200+ mph. One time I got my speedo up to that speed and it still felt like it could have kept going but I let off because the car was starting to slightly sway left and right...almost like it was rocking side to side slightly. I know these cars weren't designed for these kind of speeds like the new ones, so for my own saftey I happily let off I just wanted to hit that 200 mark once in my life, now I did so I'm satisfied and have no desire to do it again.
I will be adding a magnasun blower in the next few months with random tech high flow cats and random X pipe with GM CNC LS6 heads to replace the Katech heads. I will use stock boost. I hope to at least get some pull in 6th gear.
I heard some people are modding the 5th gear tranny by changing the gear to that of the C5 to get better top speed.
Ciao,
Californiakid
200mph is a major feat. It is harder then most people think. 206 is the best in the blue C4 (see sig). Also it is one thing to go up and touch the deuce and another to go distance at that speed. Just be safe, 200mph is not some thing you just go out and do. Check tires, inflation, all fluids (last thing you need is something locking up at speed), course pre-drive multiple time looking for hazards. this is what can happen when a tire goes away at 204: http://www.boomspeed.com/jeffyvette/Blowout.jpg
All the damage is from the explosion, I never impacted anything.
These speeds were also done at Open Road Races, the Silver state is one group see above. Another is: www.openroadracing.com
There are races June(this weekend), July and Aug.
Jeffy'
Reason: more info
The new Z06 has 0.31 Cd (Drag) 500 Crank HP...Top Speed=198 mph.
My Z06 has 0.31 Cd & dyno'd 539 on a Mustang Dyno which is about 550++ on the Dynojet. That's about 120 more HP at the wheels and the same aerodynamics as the new 198mph Z06. When I went over 200 mph the rpm's were still climbing and absolutely could have kept going.
It really felt like it could have hit 210, and without wind I bet it probably could. I wouldn't want to try it though for fear of the car coming off the ground.
As stated above...If your gonna try this just be careful & try to do it on a private airforce base or large track somewhere lol
Here's a link to some Supercharged & Turbocharged Z06 Corvettes and some other cool cars HP/TQ 1/4 Mile & Top Speed runs. www.jeff.com/lingenfelter.htm *My car has about 550RWHP & Ran 11.2 129 on street tires. These cars are rated at the Crank I believe. Most of these guys have no problem hitting the 200+ Mark. Check out this site. Very cool stuff Later guys
**Sorry I just tried it and now it's not working!! I'll get back to you on this.
