wheels, WHEELS! PLEASE HELP!
Old Jun 5, 2007 | 08:11 PM
HP Ain't Cheap's Avatar
HP Ain't Cheap
Default wheels, WHEELS! PLEASE HELP!
Help this newbie! On the inside of my ZO6 wheels it says: 17/8.5, ET56, FA162 and F/R.
The 17/8.5 is the wheel size, I think the ET 56 is the offset, I think the FA 162 refers to the manufacturer? (so says my tire guy) and the F/R indicates that it is a right front wheel.
My tire guy also says that it appears to be a GMC wheel. I'm not so sure. I thought they all said either Speed line or Alcoa.
Aftermarket wheel manufacturers, at least some, have a bad reputation. Who made my ZO6 Wheels? This is important, because if I have sub-par wheels I want to know about it. This wheel is on my '04 coupe.
Old Jun 5, 2007 | 08:14 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Well, since an OEM factory Z06 wheel never came in a 17x8.5" size, it would appear that you have an aftermarket wheel. It sounds like you're probably correct about the offset marking, but as to the others,
By the way, the '02+ wheels have "Speedline" cast into the backside of the spoke. On the '01 Alcoas, the backside is just stamped "GM".
Old Jun 5, 2007 | 09:01 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
OE Z06 wheels are 17x9.5" (54mm offset), and 18x10.5" (58mm offset).
You have reproductions.
Old Jun 5, 2007 | 09:06 PM
02MillenniumVette's Avatar
02MillenniumVette
Old Jun 5, 2007 | 09:19 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Thank you, good information as well!
Old Jun 5, 2007 | 11:50 PM
elctroman's Avatar
elctroman
<--------thats what mine are
To wheels, WHEELS! PLEASE HELP!
