Dirty Hoodliner
Old Jun 6, 2007 | 11:25 PM
LTCHAPPA's Avatar
LTCHAPPA
Default Dirty Hoodliner
Can the hoodliner be cleaned or is it better to just replace it?
Old Jun 6, 2007 | 11:28 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
If it is not too dirty or torn up, you can brush it very gently and spray with compressed air. Then paint it using high temp flat black BBQ grill paint in a circular motion.
Old Jun 6, 2007 | 11:29 PM
WetteVette's Avatar
WetteVette
I vacuum mine.
Old Jun 6, 2007 | 11:37 PM
dw99vette's Avatar
dw99vette
From: 15 miles south from the Raisin Capitol of the World Caifornia
Originally Posted by wettevette
I vacuum mine.
And if it is fuzzy, use a heat gun to shrink the fabric. I did and it looks new. But be careful because you can burn it.
Old Jun 6, 2007 | 11:42 PM
TexasMadMan's Avatar
TexasMadMan
Old Jun 7, 2007 | 01:01 AM
rws.1's Avatar
rws.1
I would avoid brushing. I could ruin the surface. Vacuuming might be Ok if their are no bristles on the attachment.
Personally with th ehood up, I spray it with a dilute solution of Simple Green.( 1 part SG/4 parts water)
Let it soak for about 5 minutes and then thoroughly rinse with your garden hose.
It that doe snot do the trick, then remove form the car and spray paint it with 2-3 light coats of Krylon or Rustoleum flat BBQ paint ( heat resistant). That will make it look like new
Old Jun 7, 2007 | 01:40 AM
doug doo wop's Avatar
doug doo wop
It isn't worth messing with those cheap liners. Go to www.carmotorsports.com and get a nice liner that won't split on the edges and you can vacuum it. They look like they will last forever and the logo is embroidered;check it out.
To Dirty Hoodliner
