Oil types?
Old Jun 7, 2007 | 12:20 PM
MN-Vette's Avatar
MN-Vette
Default Oil types?
Hello all,
I just picked up my "new" 98 convertible and I see that the previous owner was using non-synthetic oil. It has over 100K on the odometer. Should I switch back to using the recommended synthetic oil? Thanks.
Old Jun 7, 2007 | 01:25 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I would go back to mobil 1.
Old Jun 7, 2007 | 01:38 PM
87SAM's Avatar
87SAM
I would also. The previous owner used Dino just to save a couple bucks?
Old Jun 7, 2007 | 01:55 PM
reactor2's Avatar
reactor2
The difference in cost between a oil change with synthetic vs. dino isn't significant enough that I started using it in all my cars.
Old Jun 7, 2007 | 03:50 PM
rws.1's Avatar
rws.1
Any oil is better than no oil, but fully synthetic meeting GM4718M is the spec. IF you want to keep her running happily for a while use the right oil...
There are several that meet this spec including Penzzoil Platinum which you can often pick up on sale for about $3/qt.
To Oil types?
