Air Temp Control
Old Jun 7, 2007 | 03:14 PM
czrhyl's Avatar
czrhyl
Cruising
Default Air Temp Control
My readout for the outside air is wrong! It was in the 90's and it read 32. At that that reading my air won't work. Any ideas or should take it to the shop. Thanks for any info. Jim
Old Jun 7, 2007 | 04:29 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
the most common cause for the outside temp reading being incorrect is the sensor. It is located in the front end, and is easy to replace and cheapr to buy from a dealer.
Check this post for further details - http://forums.corvetteforum.com/show....php?t=1724777
