Harness bars.
Old Jun 7, 2007 | 06:05 PM
LAYNLOW's Avatar
LAYNLOW
Default Harness bars.
I'm looking to add a harness bar to my car. Does anyone have a suggestion on which one to purchase or knows if you can retain your stock belts?
Thanks!
Old Jun 7, 2007 | 06:09 PM
sailohio's Avatar
sailohio
There is a company called Arizona Speed and Marine. I bought their harness bar and like it. You can still use the stock belts. It mounts on the stock seat belt tensioners on the B pillar. The center strap on the 5 point mount on the forward seat track bolts. So it is easy on and easy off leaving no marks on the car. I'll post a link to it.
Old Jun 7, 2007 | 06:18 PM
sailohio's Avatar
sailohio
http://www.azspeed-marine.com/habaandsare1.html
Check this out
Old Jun 7, 2007 | 06:21 PM
Carz4Toyz's Avatar
Carz4Toyz
Keeping the stock belts is mandatory if you are going to street drive the car. The states that have seatbelt laws (most all of them now) mandate DOT approved "stock" belts. While the race belts may be better, may be safer, they are not DOT approved, and have not passed Highway safety test by the govenment. As silly as it sounds you could be written up for not wearing your seatbelt if you only have on your 5 point harness.
Old Jun 7, 2007 | 09:43 PM
bassvet's Avatar
bassvet
St. Jude Donor '10
Hardbar.net
Old Jun 7, 2007 | 10:17 PM
Bill Dearborn's Avatar
Bill Dearborn
Thanks!
Here are the best ones you can get that will not move if you have an accident.
Hardbar a forum vendor:
http://hardbarusa.com/hardbar/produc...products_id=39
Gary actually tested his inadvertantly when he hit the wall at NHIS with his FRC a few years ago.
Brey Krause:
http://www.ogracing.com/eshop/home.asp?categ=200
You can find this at other locations also. Should check prices at other stores to compare.
Bill
Old Jun 8, 2007 | 12:40 AM
SpeedwayZO6's Avatar
SpeedwayZO6
This is the one I am using. I love it and it holds the camera mount very well.
I got it from Motorsport Image....they are a supporting vendor.
http://www.motorsportimage.com/
Old Jun 8, 2007 | 01:08 AM
dw99vette's Avatar
dw99vette
From: 15 miles south from the Raisin Capitol of the World Caifornia
True story. My friends vette has a DVD player where the airbag goes on passenger side. His wife wears the 5 point harness because she says it is safer than stock seatbelt since there is no airbag. They were pulled over and he got 2 tickets. One for him (no seatbelt) and one for her (wrong seatbelt) In California driver gets both tickets.
Old Jun 8, 2007 | 06:19 AM
LAYNLOW's Avatar
LAYNLOW
The pic www.azspeed-marine.com shows what looks like a bracket between the seats. Does this set-up require using anything other then existing mounting points?
Thanks!
Old Jun 8, 2007 | 06:23 AM
LAYNLOW's Avatar
LAYNLOW
I like the look of this set-up!
I'm assuming this requires some drilling, etc?
Thanks!
Old Jun 8, 2007 | 10:17 AM
SpeedwayZO6
Thanks!
no drilling needed. You do need to cut the carpet slightly behind the seat.
Old Jun 17, 2007 | 06:13 AM
JustLucky's Avatar
JustLucky
How does it bolt-in? Does it use the stock locations like the other bars do? I did not see a link or product info on their website, how long ago did you purchase it? Thanks in advance.
Old Jun 17, 2007 | 07:25 AM
wayneinvirginia's Avatar
wayneinvirginia
Cruise-In VIII Veteran
Old Jun 17, 2007 | 11:20 AM
LLVETTE's Avatar
LLVETTE
Originally Posted by wayneinvirginia
I was at the shop last week and they had one on the shelf. It attaches to the upper seat belt mounts, retaining the stock belts and rests on the raised lip just behind the seats, very nice setup.
Oops, supposed to be a reply to justlucky's question.
Old Jun 17, 2007 | 11:24 AM
LLVETTE's Avatar
LLVETTE
Thanks!
I have this one and I'm happy with it. It attaches to the stock upper seat belt mounts, retaining the stock belts and then it rests on the raised lip behind the seats. The flat brace in the middle wraps around the lip to prevent front/back movement. It comes with extinguisher and camera mounts.
Old Jun 17, 2007 | 12:11 PM
AU N EGL's Avatar
AU N EGL
Brey-Krause is another one
To Harness bars.
