Spark Plug Reccomendation
Old Jun 7, 2007 | 08:36 PM
DGW's Avatar
DGW
Default Spark Plug Reccomendation
Time to replace the plugs, what should I get????
Old Jun 7, 2007 | 08:51 PM
Patman's Avatar
Patman
I just threw in a set of NGK TR55ix iridium plugs a couple of weeks ago and they honestly made a nice little difference in low end throttle response. I've also had good luck with the regular NGK TR55s in the past too. But I thought I'd try out the iridiums to see if I liked them, and I do! They should last a lot longer than the regular TR55s also.
Old Jun 7, 2007 | 08:53 PM
DGW's Avatar
DGW
Where can you get them?
Old Jun 7, 2007 | 08:55 PM
Patman's Avatar
Patman
Up here I got them at Canadian Tire, but I'm sure you'll have no problem finding them in the US at Pepboys or Autozone or AAP. If not, a few of the forum vendors will have them for sure.
Old Jun 7, 2007 | 09:02 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
Old Jun 7, 2007 | 09:30 PM
cortex's Avatar
cortex
Another vote for NGK.
I go with copper TR55 @ about $1.29 ea. Good for 40k miles, easy.
Old Jun 8, 2007 | 07:03 AM
Patman's Avatar
Patman
I found that the copper TR55s started slightly degrading after only about 15k. It was very slight, but I could notice a tiny little "bump" in the idle when my TR55s go to around 15k, and putting in fresh plugs smoothed out the idle perfectly. It was very slight, and probably didn't slow the car down in terms of horsepower loss, but even still it bothered me enough that I would change the plugs. I'm hoping the iridium plugs will at least double, if not triple the amount of time I can go before I begin to notice that slight change in idle quality.
To Spark Plug Reccomendation
