I'm looking at buying a 02-04 Z06. How generous is the space in the back? Like, could i fit a guitar case in there? Also, is there any space behind the back of the seats?
No room behind the seats but you can fit more than you think in the back, especially with no partition. Easily a set of golf clubs (or two). Depends on the size of the guitar (and case).
Pretty sure that would fit. You may have to slide it in through the doors instead of the trunk but it should definitely fit inside the trunk area.
Not trying to steer you away from the Z by any means, but the coupe C5's, due to their hatchback design, will more easily allow you you to put such a case in your trunk area since the entire rear glass lifts up (as opposed to the Z06 which literally has a trunk).
That case sould go right in through the trunk and fit in the back if there was no partition in the car. The case it pretty flat, and only 41" long and about 22" wide by 5" high.
41" long
Interior compartment: 13"W x 19-1/2"H x 2-1/4"D
