[Z06] '04 Z06 Deck Lid Problem
Old Jun 8, 2007 | 02:55 AM
gnguru's Avatar
gnguru
Default '04 Z06 Deck Lid Problem
I just purchased this car and when you pull the deck lid handle, the lid pops open maybe a quarter of an inch and you have to grab it by the edges with your fingers and pull it open. Aren't they supposed to open up farther? Is there some kind of spring to make it open or is this normal operation? Thanks
Old Jun 8, 2007 | 03:38 AM
Boomah's Avatar
Boomah
I'd say it's normal; my hatch has always been like that. I use the following technique as I normally open the hatch to get my car cover once she's all buttoned up... Push the hatch release, exit the vehicle, close doors with window up, pressure pushes hatch well open (at least an inch, easy enough to get you fingers in there). Not trying to be silly, it works & keeps from chipping the edges
HTH, Ahui hou
Mark
Old Jun 8, 2007 | 03:49 AM
Arfboy's Avatar
Arfboy
http://www.c5trunkpopper.com/
Old Jun 8, 2007 | 04:19 AM
gnguru's Avatar
gnguru
Default Thanks Guys
Thanks Boomah. I had already discovered your way by trial and error. Just wanted to be sure that it was a norm to not open further. I like Arfboy's springy deal too and will invest in one of those. Thanks for ya all's input.
Old Jun 8, 2007 | 09:05 AM
BonestockZ06's Avatar
BonestockZ06
My z always did the same thing, I use the "close the door trick" to get the trunk to pop up higher. I guess it's normal.
Old Jun 8, 2007 | 09:31 AM
Melsy's Avatar
Melsy
Default Trunk Opener
In late 2002 production or beginning '03 production a running change was made eliminating the right side trunk hinge. Due to many complaints a TSB was issued to add the right side trunk hinge if you complained about the trunk not popping up enough. I have an early '03 (#5224) and requested that the TSB be performed. They installed the right side trunk hinge--much better now but still not perfect. Hope this helps.
Old Jun 8, 2007 | 10:05 AM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Originally Posted by Arfboy
I just installed one on my Z yesterday. Works as desrcibed, now the trunk pops up 1".
Old Jun 8, 2007 | 12:10 PM
bud miller's Avatar
bud miller
i just cleaned the latch, and prop valves and added a little WD on um
mine works fine now...pops up enough for the ol fingers...
Old Jun 8, 2007 | 02:26 PM
hotwheels57's Avatar
hotwheels57
A trip to your favorite hardware store with a good selection of springs and something to protect on end of the spring/carpet (hole plug) will accomplish the same for about $5.00+/-.
Buying one after market takes the fun out of experimentation if you're so inclined.
Old Jun 8, 2007 | 04:45 PM
Warp Factor's Avatar
Warp Factor
That will work for a while. After it's remained closed for several days, you'll probably see the problem again.
Old Jun 8, 2007 | 04:57 PM
bill mcdonald's Avatar
bill mcdonald
Also, that last time I put wd40 on a air strut rod, it became trash.
To '04 Z06 Deck Lid Problem
