euro light q?
Old Jun 8, 2007 | 08:27 PM
jzemo's Avatar
jzemo
Default euro light q?
Quick question...I'm about to install my euro lights...the direction say to cut the white wire under the steering column...what is this for??
Old Jun 8, 2007 | 08:36 PM
OIF2XVET's Avatar
OIF2XVET
I hope this is a joke because you don't cut S#@*. I have the clear euro lenses and I just put them in. I have no clue what you are talking about. But don't cut
Old Jun 8, 2007 | 08:40 PM
jzemo's Avatar
jzemo
i was being honest..the directions said cut the white wire under the front steering wheel dash...but i'm not going to cut now
Old Jun 8, 2007 | 08:44 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Cutting the white wire seperates the turn signal circuit from the brakelight circuit.
If you don't cut it, your new amber turns signals will also light up when you hit the brakes.
Old Jun 8, 2007 | 08:45 PM
OIF2XVET's Avatar
OIF2XVET
I am assuming you are installing the clear euro driver lenses correct? If this is the case don't cut anything.
Old Jun 8, 2007 | 08:46 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
He's installing euro taillights, which have seperate turn signals.
Old Jun 8, 2007 | 08:56 PM
jzemo's Avatar
jzemo
yes its the euro taillights....i'm having trouble locating the harness to plug into. directions say pass side but i'm tracing the wires back but looks to be between something. are there any better directions out there??
Old Jun 8, 2007 | 08:57 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Should be right above the pass. side muffler.
Old Jun 8, 2007 | 09:30 PM
jzemo's Avatar
jzemo
good deal..the taillights are in....now for that wire...is it the one close to the center console under the steering column? i see the blue, orange and white wires...but the this also has some other colors too. it is connected into the white box
Old Jun 8, 2007 | 09:46 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
Going just by memory here...(and I installed mine like 4 yrs ago)...if you have the flat panel out above the pedals, follow the brake pedal up until you find the switch...there's only a few wires coming off it (I don't recall all the colors). There, you cut the white wire.
Do not cut it right at the switch, cut it out in the open, so if you decide to reverse this mod in the future, you have some loose wire left to splice it back together.
Old Jun 8, 2007 | 09:51 PM
jzemo's Avatar
jzemo
They are DONE!!! stand by for pics
Old Jun 8, 2007 | 10:50 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Old Jun 8, 2007 | 10:51 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Jun 8, 2007 | 11:54 PM
You definitely need to cut the white wire if you want the lights to work properly.
Old Jun 9, 2007 | 01:51 AM
DeeGee's Avatar
DeeGee
Glad you found it
The pics looked great.
Old Jun 9, 2007 | 02:00 AM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
Sounds like fun.
Paul G.
To euro light q?
