Got black interior... step inside....
Old Jun 12, 2007 | 01:06 AM
Z06ster's Avatar
Z06ster
Default Got black interior... step inside....
Fellow Corvette Enthusiasts,
I have an '02 Z which has standard issue black interior. Further, there are also C5 coupes and FRC's out there that also have black interior.
Well, my question is this... now that we're almost in summer, it's getting hot outside and I notice that while driving, the top of the black dash gets pretty pretty hot. Further, even with the A/C on, the dash still remains hot as it is in the direct sun under the windshield and not in the path of the driver comfort HVAC vents. I find myself wondering how well is this dash going to hold up say in the next 5 to 10 years from this heat??
I have been applying Adam VRT (Vinyl, Rubber, Tire) polish periodically, but with all that heat, I sure wonder how the dash is going to hold up.
Any thoughts or comments on this? I'd be really curious what people with '97 's have to say.
Old Jun 12, 2007 | 01:13 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Dont know but 7 years old dash here. Pics taken tonight!
Old Jun 12, 2007 | 01:15 AM
WetteVette's Avatar
WetteVette
I have a '97 coupe I purchased in Jan '07. Here in the central San Juaquin Valley in California, it gets into the low 100's in the summer. My car has 46,000 miles on it. I put on the last 2,000. I'm guessing the car has spent a lot of time in the garage and with the targa top on. I would not leave my car parked in the summer heat with the top off. So far, the dash is in perfect condition; and I want to keep it that way. Probably should start using the VRT. Currently just use Meguires Interior Wipes. Don't think they offer much protection from UV rays. If my dash ever starts showing signs of wear or deterioration, I would put a cover on it.
Old Jun 12, 2007 | 01:24 AM
DeeGee's Avatar
DeeGee
I ran my 02 vert in Vegas for 3 years. Summer temperatures were up in the 120s and interior temperatures even higher. I always put the roof up if I was leaving it in the sun.
Its done pretty well but there's just a trace of rippling of the vinyl on the passenger side down at the base of the windscreen if the light catches it at the right angle.
One trick I heard was to use a hyperdermic with some glue to get under the surface.
Now just need to work out where to get one
Old Jun 12, 2007 | 01:31 AM
ptindall's Avatar
ptindall
Yes, I worry about that too. My car is an '01 with 116,000 miles and had spend it's life in SoCal and now the desert of Arizona. And, it sits outside at home and work. Another problem is the windshield is soo swept, that the dash is in the sun almost all the time no matter which direction the car is parked. I use a dashmat. It's ugly, but at least it puts the dash in the shade. I also cover the car at work to protect the paint and interior. So far they are both holding up well. I don't know what else can be done.
Old Jun 12, 2007 | 01:42 AM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
It should be ok. My 97s dash is as good as new.
Paul G.
Old Jun 12, 2007 | 07:50 AM
jvette2's Avatar
jvette2
I also use a dashmat I have found that the dashmat also cuts down on
sun glare when going from a bright area into a dark area.
Old Jun 12, 2007 | 08:09 AM
mi.vette's Avatar
mi.vette
While attending college, I had a plastics course where the instructor was an engineer at GM. He stated adamantly not to use any form of product on your cars plastic parts especially Armor-all.
He explained that plastics contain a moisture content which will naturally evaporate over a long period of time. If you apply any form of moisture product to try and protect or enhance the look it will cause the moisture in the plastic to be drawn out while the product dries. This can cause cracking.
My Vette is a 2000 and I only use Pine-sol and water mixture to clean the surface. Dash and all other plastic parts are still new.
Old Jun 12, 2007 | 08:11 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
If you are worried - many vendors sell the dash cover
Old Jun 12, 2007 | 08:18 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I bought my car in Hawaii and it stays pretty warm year around. I noticed that the bezel around my dash was showing a gap between the dash itself and the bezel, so with that, I priced a new dash ( is all I can say) and went with a dash pad. This really helps out a lot and it seems to be protecting my dash. I change my pad yearly and no further damage to this area has been done, so the pad is working.
Micah
Old Jun 12, 2007 | 08:22 AM
Old Jun 12, 2007 | 08:24 AM
Cruncher's Avatar
Cruncher
I swipe a California Duster across my dash, nothing else.
Old Jun 12, 2007 | 09:20 AM
Javi1782's Avatar
Javi1782
I have a 97 no in miami fl winter does not exsist over here. I have my front windshield tinted though.
To Got black interior... step inside....
