Competion Mode (Active Handling)
Old Jun 13, 2007 | 09:38 PM
Roc87's Avatar
Roc87
Don't usually run in "comp mode", but turned it on, or turned traction control off as it may be this morning. Ended up downshifting into 1st around 23mph while changing lanes to get off the freeway and almost lost the rearend when I shifted to 2nd. Was very glad that the active handling was still on! It's all thanks to this forum that I even knew about comp mode after 2 years of driving it still surprises me how easy that rear end gets loose:o
Oh yeah, after you see comp mode on the DIC, press reset, and you can still see all the other functions and still remain in comp mode.
Old Jun 13, 2007 | 09:56 PM
Blue260's Avatar
Blue260
xxx
Old Jun 13, 2007 | 10:14 PM
WWK888's Avatar
WWK888
Originally Posted by Blue260
If you hit reset how do you know your still in comp mode? Can you toggle through your DIC and after the last info (oil temp) it will then display comp mode?
If so, I'll give it a try tomorrow on my way to work! Thanks
All you have to do is put it in Comp Mode, hit reset, then floor it and see if your tires light up or not.
Old Jun 13, 2007 | 10:42 PM
Mike Mercury's Avatar
Mike Mercury
ding... ding... ding; we have a winner !!!
Old Jun 14, 2007 | 08:16 AM
Blue260's Avatar
Blue260
xxx
Old Jun 14, 2007 | 08:21 AM
SublimeZ's Avatar
SublimeZ
From: Austin, Why are they tolling roads that are already paid for, Texas
Well I guess in 04' the comp mode is disabled when you hit reset.
I tried this morning and I believe you to be incorrect!
Mine stays in comp mode after hitting reset. (04 Z16 Z06)
Old Jun 14, 2007 | 08:30 AM
Blue260's Avatar
Blue260
xxx
Old Jun 14, 2007 | 08:45 AM
SublimeZ's Avatar
SublimeZ
how are you validating this setting because once comp mode is no longer displayed in the DIC you are no longer engaged.
Trust me, the TC is off. No "bogs" on shifts, tires will boil.
Old Jun 14, 2007 | 08:59 AM
champ53's Avatar
champ53
I have an '04 Z06 &
Old Jun 14, 2007 | 09:08 AM
threewinmag's Avatar
threewinmag
I don't know about YOUR car, but I have a 2000 and using Competition Driving mode at the track (road racing, not drag racing or autocrossing), I reset the DIC so I can keep an eye on my oil temp and I'm still in Competitive Driving mode. I'm not out of it until I either turn the car off (which resets back to normal mode) or I stop the car and change it back manually.
That's the way it was in 2000. Your results may differ.
Old Jun 14, 2007 | 09:17 AM
LMB-Z's Avatar
LMB-Z
I thought turning on Competition Mode along with a performance hood seal gave you 100 more horsepower...I guess I was wrong
Old Jun 14, 2007 | 11:54 AM
TSDuke's Avatar
TSDuke
Originally Posted by DYSTURBD
Never leave the driveway without it!
My car does not move unless it's in Comp mode.
Old Jun 14, 2007 | 12:08 PM
  #33
Mike Mercury
don't make me laugh outloud...
just because the text is removed from the DIC (when pressing the Reset button) doesn't then mean that the mode has been disabled.
we are not guessing on this
Old Jun 14, 2007 | 01:09 PM
  #34
WWK888's Avatar
WWK888
Maybe his car can't light up the tires either way so he can't tell...
Old Jun 14, 2007 | 01:10 PM
  #35
WWK888's Avatar
WWK888
And I believe you to be incorrect....
Old Jun 14, 2007 | 03:46 PM
  #36
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Originally Posted by Zenak
Is there a way on Vettes without this option to ADD this option?
It could be done but it would be expensive. Best bet would be to find a wrecked vette of the same vintage that had it and get the wiring and controls for AH out of it.
Old Jun 14, 2007 | 04:24 PM
  #37
VinnyT's Avatar
VinnyT
Almost correct. Active Handling was an option (RPO JL4) in 98-00 so some of the cars do not have it.
Bill
I concur. My 98 does NOT have it.
To Competion Mode (Active Handling)
Old Jun 14, 2007 | 05:05 PM
  #38
Blue260's Avatar
Blue260
xxx
Old Jun 14, 2007 | 05:16 PM
  #39
WWK888's Avatar
WWK888
You asked a question and we answered it. You then stated we were incorrect, when in fact you were wrong. So we (I) had a little fun with you, but do note that I added smilies and a .
I would highly recommend that you do not hang out in OT with such a thin skin, they will eat you alive. If you can't poke a little fun at your "brothers" who can you poke fun at?
Seriously if you were that offended by my remarks I apologize....
Old Jun 14, 2007 | 05:25 PM
  #40
JasB's Avatar
JasB
WWK888,
You are a class act. Well said.
Jim
