plastic vs bronze headlamp gears
Old Jun 14, 2007 | 08:42 PM
convertron's Avatar
convertron
6th Gear
Default plastic vs bronze headlamp gears
I've gone through 2 plastic gears on the drivers side headlamp in a year. Is there something I am missing? like a motor stop adjustment or something? Or do I get a bronze/brass replacement to cure this small but time consuming problem ? Thanks in advance 00 C/5
Old Jun 14, 2007 | 08:58 PM
kvozel's Avatar
kvozel
From: Centerville OH "If we weren't all crazy we would go insane"
CI 3-4-5-6-7 & 9 Veteran
St. Jude Donor '08
Get the brass one and be done with it.
Old Jun 14, 2007 | 09:21 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I've got brass ones too.....and for headlight motor gears, I recommend these!
Old Jun 14, 2007 | 09:47 PM
Secret237's Avatar
Secret237
Use the brass ones with the rubber inside ... I think Rodneys.
Old Jun 15, 2007 | 07:06 PM
convertron's Avatar
convertron
6th Gear
Thanks guys !!! The article from the web address is perfect !! Brass it is !! Thanks again !!
Old Jun 15, 2007 | 07:25 PM
MUKAK's Avatar
MUKAK
i dont get it, why do these break?
i have a 97 with 87K miles and never broke one
Old Jun 15, 2007 | 07:38 PM
blacksedan87
You must not turn your headlights on very much.....did you buy your car new? Maybe you already have the brass gears and you didn't know it.
Old Jun 15, 2007 | 07:43 PM
WetteVette's Avatar
WetteVette
Maybe you don't drive much at night? Don't know. My '97 has 46,000 and as far as I know it has the original nylon gear. If you read the article on the link above, it explains why the gear fails.
Old Jun 15, 2007 | 07:48 PM
MUKAK's Avatar
MUKAK
drive every other night, i bought the car 7 years ago put 66K miles on it...
and I opened the casing of the headlight motor to check if it was brass or plastic and it was plastic...
Old Jun 15, 2007 | 08:03 PM
blacksedan87
I don't know what to tell you then, my friend......you must be lucky.
Old Jun 15, 2007 | 09:24 PM
02MillenniumVette's Avatar
02MillenniumVette
Old Jun 15, 2007 | 10:11 PM
MUKAK's Avatar
MUKAK
lucky I am
i bet it will break in the next few months
Old Jun 15, 2007 | 10:16 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
lucky I am
Old Jun 16, 2007 | 02:02 AM
Choreo's Avatar
Choreo
Not that it matters, but are the brass gears noisier?
Old Jun 16, 2007 | 07:15 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Possibly, but the open/close cycle is so sort, it really isn't all that noticible.....BTW, I got brass ones!
Old Jun 16, 2007 | 09:48 AM
lytspeed1's Avatar
lytspeed1
I put the brass gears in mine recently...now it's back to making the grrrrrrrrrr noise again when I turn the lights off.......motor housing appears to be slightly loose though....prob that nowwww...........
Old Jun 16, 2007 | 09:50 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I have a brand new set of brass ones I bought from MID-AMERICA I will never be using because I just bought a set of SW C5R headlights w/ HIDS.
I am willing to part for a fair price.
To plastic vs bronze headlamp gears
