Mpg Question
Old Jun 14, 2007 | 10:10 PM
steves65korvette's Avatar
steves65korvette
Default Mpg Question
I have seen a lot of posts here about gas mileage, and mine does rather well. But, I have not gotten above the mid 20's doing the math myself per odometer and gallons used.
My question is about the 30 mpgs. "Is anyone doing the math or are these strictly from the DIC reading".
My DIC says I am getting better than I really am...Just curious I guess as I am satisfied with the mileage I get especially with a car that performs like this. '99 FRC
Steve
Old Jun 14, 2007 | 10:13 PM
photoguy's Avatar
photoguy
I did actually get 28 mpg on the PA Turnpike driving in 6th gear.
Old Jun 14, 2007 | 10:19 PM
rws.1's Avatar
rws.1
Actual 32.7 mpg at 70 mph 6th gear on cruise control on a 5 hr hwy stretch....
Old Jun 14, 2007 | 10:29 PM
WetteVette's Avatar
WetteVette
Default Mpg
I'm guessing the DIC is pretty accurate. Remember, you're getting an AVERAGE.
I've never divided miles by gallons used. Probably should just as a double check.
Old Jun 14, 2007 | 10:31 PM
Jet-Jock's Avatar
Jet-Jock
Oh goodness, yes I was getting about 425 miles per tank of gas on my trip to Bowling Green. Set the cruise between 70-80 in 6th. In town I usually get maybe 275 miles per tank of gas.
So doing the math, about 15 gallons per fill up on the trip for 425 miles is about 28.33 miles per gallon.
Old Jun 14, 2007 | 11:08 PM
docohm's Avatar
docohm
2001 A4 Coupe, I35 to I40, 700+ miles, 25.5 MPG calculated from gals used. A/C on all the way. ~80 MPH most of the way (don't tell Smoky!)
Save the wave.... Doc
Old Jun 14, 2007 | 11:10 PM
NOS500's Avatar
NOS500
I get about 27-28 on the highway at 80 mph, with my 4.10s.
In the city I can get about 18-19 if I try, but thats no fun so I get about 14. haha
Old Jun 14, 2007 | 11:29 PM
hotrod03's Avatar
hotrod03
I had a H/C change z06 ported heads, a big cam. LT headers and i am getting better gas milage with the engine modded due to the excellant breathing. I have 435rwhp m6. I am getting 33.5 mpg at 70mph with the air on! I could barely reach 30mpg. stock.
Tom73's Avatar
Tom73
I would think that the DIC would be more accurate then any manual system as it would be almost impossable to get the tank full to the same level each and every time.
Old Jun 14, 2007 | 11:38 PM
Red73Vette's Avatar
Red73Vette
Last fall I did a run of 805 miles to Milwaukee and southern MN. The DIC said 33.5, I did the gallons and miles and came up with 32.5 MPG, of course, I did not go over 70 mph unless in MN then 75 and back to 58. Oh ya, did I mention a six speed with 65,000 miles on it?
Jerry
Got 73 for sale, love it but have no garage room in winter.
Old Jun 15, 2007 | 01:12 AM
UR LZN's Avatar
UR LZN
I have a buddy who ran from Oregon to San Francisco last month with an '04 Z06. His computer read 32.9 m/g (yep, nearly 33 mpg) when he arrived home.
I also have a Pontiac GTP and the computer will tell me I used 13.4 gallons and the tank will take 14.3 to fill it. It can be as much as a gallon off, so when it's calculating m/g, it's using less gas than what was actually needed giving a higher m/g reading!
Ya gott-a watch those computers!
Hmmmm....Maybe I need to manually calculate on the Corvette.....
Old Jun 15, 2007 | 01:22 AM
DeeGee's Avatar
DeeGee
Best I ever did was 28mpg but I guess the A4 doesn't do as well as the MN6
Old Jun 15, 2007 | 06:24 AM
Yes, I have gotten better than 30 mpg when I have calculated it by hand. The DIC may be a little high, but not by much in my experience.
Old Jun 15, 2007 | 11:41 AM
OH Vette's Avatar
OH Vette
Have gotten 31 mpg on the expressway
Old Jun 15, 2007 | 11:50 AM
LTVetteVert00's Avatar
LTVetteVert00
Final drive ratio on A4 is not as good as the M6. Not sure if that is true with the newer A6?? My best is around 28, too.
LT
Old Jun 15, 2007 | 12:00 PM
87SAM's Avatar
87SAM
Yes, the DIC is pretty accurate. Every time I have calculated it, I found the DIC to be 1 – 1.5.mpg optimistic (both during city/play driving or long cruses). On long 75-85 mph cruses the DIC shows 33mpg.
Patman's Avatar
Patman
I have found the DIC to be very accurate. If you figure out your gas mileage over more than one tankful (such as figuring it out over a month or two's worth of driving) you'll find that the DIC is almost right on the money (on mine it is within 0.2 MPG)
I get 18-19 MPG in mixed driving (tons of rush hour traffic) and 28-30 on long highway trips.
To Mpg Question
Old Jun 15, 2007 | 12:06 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Averaged 32.2 coming back from BG CI. The DIC said 32.3, but the calculator was 32.2. 70 + air on.
Going down was less 30.4 Targa off and 70-80. Seems I get better milage with the top on windows up and air on. Go figure.
Old Jun 15, 2007 | 12:24 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
And you didn't stop by to say Hi???? .
Old Jun 15, 2007 | 12:37 PM
DefenderC5's Avatar
DefenderC5
How do you figure? The pump shuts off at pretty much same time since the federally mandated vapor recovery/over flow prevention systems are all pretty regulated.
I found the most accurate system is to:
1) Reset Trip meter during last full fillup
2) At next fillup, divide the number of miles on the trip meter since last fillup by the number of gallons needed to fill tank.
I average 22 mpg in the city/short distance highway. Long distance highway is 28-29 mpg with spirited passing/highway onramps. I can crack 30 mpg with conservative driving on the highway.
The results are pretty consistent considerring my driving style doesn't vary too much. I think that's pretty accurate IMO.
