Climate control temp loses its memory!
Old Jun 15, 2007 | 06:13 PM
tk97's Avatar
tk97
Default Climate control temp loses its memory!
I would set the climate control from default temp, 73 degrees, to my desired temperature, lock it in the memory mode (on my door) and 15 minutes later it would reset back to 73 degrees. What is causing it do this? Any one have this problem, its driving me?
Old Jun 15, 2007 | 07:31 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You will need a Tech2 scan tool to diagnose it properly or take it to the dealer. Will make a guess that the BCM has has a problem or the LDCM itself is doing something on its own.
Old Jun 15, 2007 | 07:46 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
could be battery
Old Jun 15, 2007 | 08:53 PM
tk97's Avatar
tk97
I think so too, I ran the codes and one of the BCM codes came up. Time to do a bit of research.
Old Jun 15, 2007 | 08:54 PM
tk97's Avatar
tk97
Originally Posted by Zilla
could be battery
True, I have had a few electrical issues lately that might stem from the battery. My friend is a mechanic so I'll have him test it to see how strong/weak it is.
Thanks for the suggestion!
To Climate control temp loses its memory!
