I have searched but did not get the answer I wanted.I have a 2002Coupe with the LS1 350 HP.Ok what makes the 2002 ZO6 LS6 engine have 405HP?They are both 5.7L.
I'm far from an authority on such matters, but I believe the difference is the intake manifold, heads, cam, crank, exhaust system are combined to create the additional horses and torgue.
I believe it's the heads, cam, lack of pre-cats, and raise in RPM limit that actually give it the extra 55hp. The heads flow better and raise the compression to 10.9:1. I believe all 2002+ LS1 engines share the same intake,thin-walled exhaust manifold, and block with the LS6 engine.
Basically in a nutshell, although I do believe all 2001+ LS1 engines have the LS6 intake.
Corvette LS1 vs LS6:
-different head castings (LS6 flow slightly better stock) 241 on LS1, 243 on LS6, LS6 heads have sodium filled valves for lighter valvetrain weight and a smaller combustion chamber for higher compression.
-All 2001 and newer Corvettes and F-body LS1s have the LS6 intake.
-different cam specs (02-03 LS6 cam is much better than 01 or regular C5)
-different PCV system
-slightly different block internals (crankcase port windows larger on LS6)
-same crank and rods, I believe pistons are a bit different
KC
The intake on the '01-'04 LS1 is the same as the LS6.
Originally Posted by Zilla
yeah something along the to what he said
plus the compression is higher
