373 gear ???
Old Jun 16, 2007 | 10:07 AM
4deatr's Avatar
4deatr
Default 373 gear ???
Has anyone put in the 373 ring and pinion set in? Do the gears make noise? Is the ring and pinion set just as good as a new 373 differential?
Old Jun 16, 2007 | 02:48 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
If done right, and broken in right, no whine or noise.
Contact forum vendor Cajundude. He will hook you up.
Old Jun 16, 2007 | 05:00 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Marty, have you talked to Kerry (Jamison) about your question. I asked him that question about a year or so ago and it can be done and as Nouman states above, if done right you are fine, but if done wrong you are screwed and out more money than it's worth. Personally going the extra step and spending a little extra money is the way I would do it, but that is just me. BTW, if you do it and need someone to tune it let me know, there is a guy in my command (LT in the Navy) that has been tuning for free (you pay for the certificates to HP tuner - $100-$200) and does a GREAT job and I can get you two together for some tuning. (A tip for his help would be .)
If this were a POLL I would vote - DIFF with 3:73 vice the ring and pinion.
Micah
Old Jun 16, 2007 | 05:08 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I've changed mine twice in my diff now. You can put whatever ratio (made for the C5/C6) you want in there. Yes, it is the ring and pinion. Now if you have a 2.73 carrier now you will either need to get a later series carrier or go through DTE for the work. It is a lot cheaper than buying a new rear end for sure, however, you do need to find someone who knows the Getrag diffs cuz they are a different animal. It is not really a DIY like a Ford rear end.
Old Jun 16, 2007 | 10:30 PM
Nyvetteguy007's Avatar
Nyvetteguy007
I had the dreaded rear end leak in my car...(6 spd)...while the rear was out I had 4.10's put in.....LOVE them....
Old Jun 17, 2007 | 08:46 AM
4deatr's Avatar
4deatr
Micah
Thanks for the info Micah. I had Mike from Columbia Corvette tune my car and he will retune it fro free as long as I have it.
I think I will just get the differential.
Old Jun 17, 2007 | 08:47 AM
4deatr's Avatar
4deatr
I have the 315 right now. What kind of mpg would I get with the 373?
Old Jun 17, 2007 | 03:44 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Probably close to a 2-3 mpg loss with the gear change (the one you mentioned), but the fun factor is worth it!
Old Jun 17, 2007 | 08:41 PM
cherzra's Avatar
cherzra
Can you please explain the differences with other gears? Is it a higher top end? Or accelleration at lower speeds?
Old Jun 17, 2007 | 11:04 PM
4deatr's Avatar
4deatr
I have the 315 now if I go to the 373 I will have more accelleration and not have the top end I have now.
Old Jun 18, 2007 | 03:59 AM
BGDDYKWL's Avatar
BGDDYKWL
I'm strongly considering doing the ring and pinion swap rather than the entire differential as I have the 3.15s now. Thinking about 3.90-4.10. Where would I be able to find the ring and pinion for a C5 (2000) and roughly how much should I expect it to cost? Thanks in advance.
Old Jun 18, 2007 | 05:36 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
Old Jun 18, 2007 | 08:49 AM
Cajundude's Avatar
Cajundude
The higher the ratio the more snappy it will be off the line. Do you lose top end speed? Well, yea, but instead of doing 175 mph you will be drastically dropped to about 165.
To 373 gear ???
