Jack for C5
Old Jun 19, 2007 | 12:57 AM
Jistari's Avatar
Jistari
Well for some reason I cant post the link :
http://forums.corvetteforum.com/show....php?t=1714738
but I think that was the post that I bookmarked about a different type of jack (goes under or around wheel) that was zero low profile and needs no room next to vehicle.
I was looking at it because my garage is too narrow to even open the doors properly let alone use a jack from the sides.
But, Im having the driveway blacktopped next week
(no more $100 oil changes....weeeeee...)
Old Jun 19, 2007 | 02:19 AM
Barney Rumble's Avatar
Barney Rumble
Default A jack by any other name could be the same...
Originally Posted by csexton
This is what I use. It does a great job! http://www.northerntool.com/webapp/w...3500_200313500
Chuck
I just followed your thread - I have a Craftsman 4,000 lb jack that looks identical to this one, except it is red and cost twice as much!
Old Jun 19, 2007 | 10:24 AM
Husker67's Avatar
Husker67
This is a good jack, light and very low, 3.5". Sams Club, $100.00
Old Jun 19, 2007 | 11:44 AM
OvrEagR's Avatar
OvrEagR
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Chuck
I have been using that same one also, works great!
Old Nov 24, 2007 | 09:04 PM
robsc501's Avatar
robsc501
Default JACK for the c5
HI there c5Aggie03,
You probably bought a jack already.Anyway here goes.
I just bought this low profile "black jack" 3ton made by torin at walmart.Min height 3.3" to 17.72" professional quailty very heavy. Cost 68.62. This jack will fit under the jacking pucks with lots of clearance to spare. You can jack the car with out using car ramps.My regular 3ton floor will not fit under any jacking puck without using a 2x10 under the wheel. I have a completely stock 01 vette coupe non zo6 not lowered at all.My lowest side of the car measures 4 3/8" from the garage floor to the bottom of the jacking puck.I keep a set in the trunk wrapped in a towel just in case of a unexpected trip to the garage.I just used the jack today & manually bled all the brakes as to remove the dirty factory brake fluid. (in from day one).Brakes & the jack work fine.
robsc501
Old Nov 24, 2007 | 10:40 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Originally Posted by Hardcorvette
THIS is what you need...AC Hydraulics DK13HLQ http://www.asedeals.com/hydraulicjacks2.html
Old Nov 25, 2007 | 10:15 AM
bucwheat's Avatar
bucwheat
Yea, as stated go with the low profile,or be cursed with the old wooden block sindrone for ever
Old Nov 25, 2007 | 12:22 PM
American Hydrocarbon
Guest
Posts: n/a
Originally Posted by jovette
I just saw one in Walmart, a steel floor jack that has a 3.3" minimum height, which is what you need when using the 'pucks' on a C5. Believe the price was right @ $60.
Would you trust this jack to lift your baby? You get what you pay for. I went that way once but never again. Buy quality - get quality.JMHO
Old Nov 25, 2007 | 12:33 PM
vetter79's Avatar
vetter79
Air powered, 30" jack!!
Old Nov 25, 2007 | 01:01 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Mine is a crewline from Sams, Its about 100.00 USD
