Gassing up issue
Old Jun 18, 2007 | 02:43 AM
Big Jay E's Avatar
Big Jay E
Default Gassing up issue
In just the past two weeks, I have noticed that when I am gassing the vette up, that the auto filler will click off with only about 6 gallons in the tank. Then I have to finish it by hand going very slow like I am topping off and I can get another 10 gallons in. Anyone else have this happen?
Jay
Old Jun 18, 2007 | 06:48 AM
Do you always fill up at the same station? Perhaps their pumps are very sensitive to the pressure buildup when you fill the tank and that is causing it to shut off early. I haven't noticed that problem with mine.
Old Jun 18, 2007 | 07:42 AM
tellefan's Avatar
tellefan
On 04's there is a problem with the gas filler tube. I think your car is an 03' but you might want to check with a dealer depending on when your car was built. David
Old Jun 18, 2007 | 07:56 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old Jun 18, 2007 | 08:00 AM
bb609's Avatar
bb609
My '03 has the same issue. Just run the pump slower although there is a new filler neck that you can buy to solve the problem. A search should find you the correct part number.
Old Jun 18, 2007 | 11:11 AM
mag red vette's Avatar
mag red vette
I have an '04 that lately seems to have the same problem. Any suggestions as to the remedy?
Old Jun 18, 2007 | 01:03 PM
WWK888's Avatar
WWK888
Read the post right above yours.
Old Jun 18, 2007 | 03:24 PM
bb609's Avatar
bb609
Here is the tech bulletin regarding the filler hose:
http://www.corvetteactioncenter.com/....php?qstId=542
Old Jun 18, 2007 | 03:41 PM
uk_vette's Avatar
uk_vette
Confirmed.
2004 are slow to fill,
Why?
I, just like you mentioned, can skuirt in abot half tank, no problem,
Then it takes me ages to fill carefully, on hand, so it don't keep tripping off.
Looking at the bullitin, is this a free swap out by the GM dealers?
To Gassing up issue
