how to install convertible class
Old Jun 19, 2007 | 09:28 PM
uniquec5's Avatar
uniquec5
Default how to install convertible glass
The glass in my vert is comming out. What type of glue is used to secure it back in and how did you do it??
thanks Sonnie.
Old Jun 19, 2007 | 10:45 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Might get more posts if you edit your thread title. It says class not glass
Old Jun 19, 2007 | 10:49 PM
Luv My Vette's Avatar
Luv My Vette
Yeah I came here wondering how you classed up your vert
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Old Jun 19, 2007 | 11:05 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
PM a Mod and they can change your title for you
Old Jun 19, 2007 | 11:21 PM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
Default okay, now that were back on glass
No fix will fix it. I'll say it again, No fix will fix it but a new top. Some people will post that they have used 3m tape, silicon, JB weld, wrigleys gum, whatever..nothing will work permently. New tops are about $1200 installed. Have a nice day.
Old Jan 19, 2008 | 09:31 PM
uniquec5's Avatar
uniquec5
Well I used black urethane 7 months ago and still no problems, so there is a fix to this!! and it only cost 5 dollars not 1200. But thanks anyway.
I would not recommend using the black urethane on anything else then a black top
Old Jan 19, 2008 | 09:50 PM
4deatr's Avatar
4deatr
I reglued mine I have had it fixed for over a year. I think it was Gorilla Glue. I used something to press on the glass from the inside and left it that was for the weekend. A year may not be permently fixed but it was only $4.00
Old Jan 20, 2008 | 02:45 AM
DeeGee's Avatar
DeeGee
I think this is the best post on how to refix the window. No idea how well the repair held up but I'd certainly give it a try before I shelled out for a new top
Best of luck
http://forums.corvetteforum.com/show....php?t=1766844
Old Jan 20, 2008 | 03:38 AM
WildTurkey's Avatar
WildTurkey
"How to install convertible class"...buy a vert!!!
Just kidding - best of luck with you window repair!
Old Jan 20, 2008 | 06:22 AM
vetter79's Avatar
vetter79
Just ordered a bottle of Rhino Glue to keep in stock for myself too!
Old Jan 20, 2008 | 10:09 AM
cletus's Avatar
cletus
Sorry, but that's not true. I used the fix here <http://forums.corvetteforum.com/show....php?t=1766844> a year ago and even through below zero weather and over 95F it's strong and perfect looking as new.
I just put a pillow under the window to press it into the top and didn't use the window suction devices, either. Real easy and cheap.
Good luck.
Old Jan 20, 2008 | 10:12 AM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
So, tell us if you've tried it, or are just posting to stir the post
Many members have done this 'fix' - I've never seen a post from them it failed
Old Jan 20, 2008 | 11:28 AM
Junkman2008's Avatar
Junkman2008
Old Jan 20, 2008 | 11:44 AM
fuel_junkie's Avatar
fuel_junkie
I used the rhino glue method. At first I had a couple of problems with it after a month but I took off the old glue, cleaned up the areas really good. Now its been 4-5 months with no problems and no leaks. Its really worth the effort and takes about an hour to do properly go to www.rhinoglue.com I paid for the $17.00 bottle and still have enough left to do it again.
Old Jan 20, 2008 | 01:19 PM
uniquec5's Avatar
uniquec5
Originally Posted by Junkman2008
I CHANGED IT IN MY HEADING BUT I CANT CHANGE THE TITLE.
IT IS KIND OF FUNNY
Old Jan 20, 2008 | 02:45 PM
DavzC5's Avatar
DavzC5
I said that back in June and after I "stirred" up the post a member recommened Rhino glue and I tried it and it has worked ever since. I was a little frustrated back then because I tryed everything for over a year. Since then I have posted numerous times to use the industrial Rhino as a good fix.
To how to install convertible class
