[Z06] Amp location?
Old Jun 19, 2007 | 10:15 PM
smoothblue's Avatar
smoothblue
St. Jude Donor '12
Default Amp location?
Is it o.k. to mount the amp under the passenger side seat? Has anyone done this?
Old Jun 20, 2007 | 12:19 AM
striper's Avatar
striper
Only my uneducated opinion but the only negative I can see is possibly excessive heat being retained because of the seat being above it. Otherwise, there is nothing there to interfere with the amp.
Old Jun 20, 2007 | 04:48 AM
Switchbarrel's Avatar
Switchbarrel
I've had my JL Audio amp under my passenger seat for over a year now. My car's a daily driver (ie, amp is used daily) and no ill affects (effects?) yet.
-Rick
Old Jun 20, 2007 | 12:43 PM
deathinnovember's Avatar
deathinnovember
-Rick
ha if you daily driver your z06. What are the other cars for haha.
Old Jun 20, 2007 | 02:09 PM
fej's Avatar
fej
I daily drove my 01 z for about 1.5 years without issue with the amp underneath the passenger side seat. Amp needs to be relatively small and not very tall .. IE 14-15" long and under 9.5" (IIRC) wide by 2" or less tall otherwise you run into the seat resting on top of the heat sinks or scratching/getting stuck on the amp when the seat moves on its rails.
I fit a 17" x 8" x 1.5" amp underneath my seat, and it sits about 2" out from under the passenger seat but is covered by my Lloyd's front mat.
IMO it is a good spot for amps that are not prone to huge heat. If they get a little warm when you are cranking it up you are gtg.
Fej
Old Jun 20, 2007 | 09:26 PM
ptindall's Avatar
ptindall
Driving to work when the Z06 is being modded.
Old Jun 20, 2007 | 09:30 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
Cruise-In VII Veteran
St. Jude Donor '05-'06-'07
plenty of room in the Z06 and I travel light...
Old Jun 21, 2007 | 05:07 AM
Switchbarrel
Z06 = 470 hp commuter
Acura = Family car
Toyota = Towing the boat and carrying lots of guns to the range of course...
-Rick
To Amp location?
