hood seal question
Old Jun 19, 2007 | 11:57 PM
RedRckC5's Avatar
RedRckC5
Default hood seal question
does anyone have the hood seal installed on their car? i just received mine from WCC and i also the vararam. does it really keep under the hood clean? and how about cowl cover filter? it suppose to keep the air coming into the cabin clean. thanks.
Old Jun 19, 2007 | 11:59 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Originally Posted by RedRckC5
does anyone have the hood seal installed on their car? does it really keep under the hood clean?
yes
and dry too.
Dirt and water will still find their way. Just keeps a lot out.
Old Jun 20, 2007 | 12:02 AM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Originally Posted by Mike98SilVert
yes
and dry too.
Old Jun 20, 2007 | 12:03 AM
RedRckC5's Avatar
RedRckC5
thanks...waiting for the temp to go down and work on the car. it's 9 pm and it's still close to 100 in the garage!
Old Jun 20, 2007 | 12:06 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
When you install the hood seal (assuming that it's not too late and you already did it), install it so that it's about 1/8" back from the edge (see pic)
That way - when you close the hood - the hood seal will not show and will not be pinched by the hood. I've had mine installed for over three years and I have not had a problem - keeps a lot of the dirt out and almost all the water too.
One final tip - make very sure that you have the surface clean and totally free of wax. Use mineral spirits or 3M Wax and Adhesive Remover to prep the surface.
Old Jun 20, 2007 | 12:07 AM
GS Ron's Avatar
GS Ron
I put a seal on mine a few years ago
It sure helps keep the dust and water out.............
Old Jun 20, 2007 | 12:13 AM
RedRckC5's Avatar
RedRckC5
thanks for the tip. will do it thursday because it is still too darn hot. will it keep fine desert sand out? darn dust devils this time of year.
Old Jun 20, 2007 | 12:22 AM
blacksedan87
I live in the Phoenix area - yes it will.
And what do you mean it's "close to 100" in your garage....GET TO WORK!
Old Jun 20, 2007 | 07:14 AM
IMO, yes the hood seal does keep some dust from getting into the engine bay. It also helps keep some water from getting in there.
Old Jun 20, 2007 | 07:22 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old Jun 20, 2007 | 07:48 AM
Oldvetter's Avatar
Oldvetter
I have the hood seal and the cowl filter. I know both work well.
Old Jun 20, 2007 | 07:52 AM
vermjpv's Avatar
vermjpv
Now a CTS-V Owner
CI 5-6-7 & 9 Veteran
St. Jude Donor '05-'06-'07-'08
It's well worth the money and effort!!!
Old Jun 20, 2007 | 08:05 AM
NamVette04's Avatar
NamVette04
NCM Member '09
Default best part
Don't forget about the extra 16 HP that you get.
Old Jun 20, 2007 | 08:19 AM
Blue260's Avatar
Blue260
RedRckC5
GREAT TIP!
Old Jun 20, 2007 | 11:02 AM
02MillenniumVette's Avatar
02MillenniumVette
No, its 20hp and if you get the door seal and tail light seals you will gain 75hp.
Seriously I have the hood seal and it does keep dirt and water out of the engine bay.
Old Jun 20, 2007 | 12:02 PM
jrose7004's Avatar
jrose7004
They do help plus they add 5HP!
Old Jun 20, 2007 | 12:16 PM
LMB-Z's Avatar
LMB-Z
I have one on mine but I was told it added 50 hp..I don't really know
To hood seal question
Old Jun 20, 2007 | 12:26 PM
hotwheels57's Avatar
hotwheels57
...and don't forget the or someone will start that topic again...
Old Jun 20, 2007 | 12:28 PM
02MillenniumVette
No, that would never happen here.
Old Jun 20, 2007 | 09:50 PM
waunavet's Avatar
waunavet
St. Jude Donor '20
Originally Posted by mph1972
