Fuel additive?
Old Jun 20, 2007 | 07:07 AM
rwilkins's Avatar
rwilkins
Default Fuel additive?
I always use Sunoco 93 octane. Should I throw in an additive now and then? If so, what and where do I find it? I only drive vet maybe 100 miles a week(on the week-end...nice weather) Thanks in advance
Old Jun 20, 2007 | 07:16 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Put in Chevron Techron.
Old Jun 20, 2007 | 07:22 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
A can of SEA FOAM goes in my tank two to three times a year. Best stuff on the shelf.
Old Jun 20, 2007 | 07:35 AM
PYRO1's Avatar
PYRO1
Cruise-In VII Veteran
Old Jun 20, 2007 | 07:59 AM
rwilkins's Avatar
rwilkins
Where do I find this Sea Foam please? And the Chevron Techron; Additive or type of octane from the pump?
Old Jun 20, 2007 | 08:07 AM
Vette Girl's Avatar
Vette Girl
Cruise-In IV Veteran
That's what I use and it works great!
Old Jun 20, 2007 | 08:16 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
Almost every AUTO PARTS store should have it:
AUTOZONE
PEP BOYS
ADVANCE AUTO
NAPA
etc.
Micah
Old Jun 20, 2007 | 08:23 AM
Blue260's Avatar
Blue260
I thought the additives already in gasoline was enough to clean the injectors.
Didn't GM list certain Top Tier Gas Stations. And, I thought some additives could possible damage the internals of the injector.
Old Jun 20, 2007 | 08:26 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
You are right, there are some additives in the TOP TIER, but SEA FORM does more than act as an ADDITIVE, it is a cleaning agent and does wonders. Check out there website and I also encourage you to call them up and ask questions (I did) and learned that there is only one product for me to my tank and that is SEA FOAM.
Old Jun 20, 2007 | 08:29 AM
VinnyT's Avatar
VinnyT
This is what you'll need to look for R.
Old Jun 20, 2007 | 10:00 AM
rws.1's Avatar
rws.1
Seafoam
Old Jun 20, 2007 | 10:06 AM
mph1972's Avatar
mph1972
St. Jude Donor '07
That is the can!
Old Jun 20, 2007 | 10:32 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Best stuff going. Use the vacuum from your brake booster to suck it into your intake. Do this SLOWLY for about a 1/4 of a can. Then stick the hose in the can until the engine dies. Let sit for about twenty minutes or so. Start engine and run at 1800-2000 RPM's. Watch the show! I do all my cars this way once a year, and you should see smoke, it's outrageous! The first time I did it, my neighbor(Sea Foam convert) came running over. He thought the car was on fire! The smoke will clear in a couple minutes, and the entire upper half of your engine will be nice and clean. Doesn't harm 02's, cats, or fuel system. Add a can or two a couple times a year to keep tanks, lines, and fuel system clean.
We pulled apart a buddies engine(84 C4) who uses Sea Foam faithfully. I've never seen a fuel system in that condition. It was spotless. Even the valves were clean as a whistle. AND the engine had 240,000 miles on her when the oil pump went kaput. Now THATS some kinda clean!
Old Jun 20, 2007 | 10:39 AM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
Never used SeaFoam, but did use Techron in my 98 Vert. At year 2000 the gas tank issue hit. Used it in 2 tanks in a row and never had any more problems After that I use a bottle every 4-5 tanks of gas. Sold car in 2005.
Old Jun 20, 2007 | 01:37 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
torco is the best additive
Old Jun 20, 2007 | 02:56 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Do NOT! put in Octane Boost on top of Super Unleaded (91-93 Octane)
It will slow down the burn rate (or as I like to say it make it to thick!) and give you less performance!
If your looking for a cleaning additive them you could try Sea Foam!
Thanks,Matt
Old Jun 20, 2007 | 03:19 PM
drews60's Avatar
drews60
Guess its time to try Sea Foam on my Vette. Thanks for the endorsements.
To Fuel additive?
Old Jun 20, 2007 | 04:02 PM
jrose7004's Avatar
jrose7004
I use it about every 3000 miles!
Old Jun 20, 2007 | 06:14 PM
1FASTVERT's Avatar
1FASTVERT
St. Jude Donor '12
I just bought 2 bottles of Gumout maximum clean at Autozone. They are having a sale on them. They were FREE. Buy 2 and you get your money rebated back to you by mail. Not a bad deal. I know that Gumout is a good brand. Maybe not as good as Seafoam but it should do the job and keep $13 in my pocket.
Old Jun 20, 2007 | 07:44 PM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
Lucas oil fuel treatment for me.
Compare to Seafoam.
http://www.lucasoil.com/products/dis...tid=2&loc=show
