Engine seals/ gaskets
Old Jun 21, 2007 | 01:01 PM
GOTHAM VETTE's Avatar
GOTHAM VETTE
Default Engine seals/ gaskets
Good afternoon gents, quick question for you.
I'm in the process of installing my new engine and I was wondering if I need to change all of my seals and gaskets or not? I have the book by Will Hanzel and in it he recommends not reusing any of them since they
are " of the compression-carrier design. This means the aluminum surface of the gasket takes the torquing load to control how much compression the embedded silicon sealing surfaces experience."
Also can I reuse the front and rear Crank seals or should I swap them our while I'm in there? Last but not least do I need the seal alignment tools for these?
Many Thanks,
Matt
Old Jun 22, 2007 | 12:01 PM
GOTHAM VETTE
ttt
Old Jun 22, 2007 | 12:12 PM
Blown 346's Avatar
Blown 346
I would replace them, if you dont they will end up leaking on you. I believe you will nedd the alignment tool to not gouge or tear the new seal once it goes in. Make sure the seals are lubricated for ease of the install.
To Engine seals/ gaskets
