Lug nut toruqe?
Old Jun 21, 2007 | 06:05 PM
c5crusr's Avatar
c5crusr
From: Corona CA, sometimes Austin TX or Las Vegas NV
Default Lug nut toruqe?
98 C5 lug nut torque is ???
Dealer says 100ft lbs
WCC says 80ft lbs
Eklers says 125ft Lbs
What does the forum say???
Running http://www.westcoastcorvette.com/p-1...e-package.aspx
Old Jun 21, 2007 | 06:10 PM
Fast98's Avatar
Fast98
Old Jun 21, 2007 | 06:12 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
jeff
rcs128's Avatar
rcs128
100, at least for GM wheels. I don't know if aftermarket wheels would be any different.
Virtual Geezer's Avatar
Virtual Geezer
I believe my owner's manual (2004 targa coupe) says 100 ft. lb., assuming OE wheels. Many other GM vehicles are also listed at 100 ft. lb. (I own several).
Old Jun 21, 2007 | 06:16 PM
Janster's Avatar
Janster
Originally Posted by Fast98
100
..and if you use air tools/impact gun - you can get a 100lb torque stick.
Old Jun 21, 2007 | 07:35 PM
csexton's Avatar
csexton
I use 3 passes, 30, 60, 100
Chuck
Old Jun 21, 2007 | 07:41 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
100 lb ft. - tightened in a "star" pattern. I use this on my aftermarket iForged wheels without any issues.
Old Jun 21, 2007 | 09:41 PM
rws.1's Avatar
rws.1
100 ft-lbs . Clean, dry, non- lubricated studs
Old Jun 21, 2007 | 09:42 PM
Bob CTS's Avatar
Bob CTS
Old Jun 21, 2007 | 09:43 PM
c5crusr's Avatar
c5crusr
100 it is. Thanks everyone for the info.
Great site!
Old Jun 21, 2007 | 10:34 PM
ROJ#79's Avatar
ROJ#79
Old Jun 21, 2007 | 11:57 PM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
I personally do not think torque sticks are all they are cracked up to be... Too many times I've seen warped rotors that were tightened by Torque sticks... But when I've consistantly used a Clicker torque WRENCH, no problems at all...
Maybe the torque STICKS were used improperly? Anyway... DO what you want.. it's your car!!
Old Jun 22, 2007 | 12:20 AM
ALLEGRO's Avatar
ALLEGRO
Put me down for 100#
Old Jun 22, 2007 | 02:57 AM
c5crusr's Avatar
c5crusr
I have the Clicker type also. Seems to work out fine for me.
Old Jun 22, 2007 | 06:38 AM
I torque mine to 100 ft lbs.
Old Jun 22, 2007 | 06:55 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
100-105 here.
Old Jun 22, 2007 | 02:14 PM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
Originally Posted by mph1972
100-105 here.
Same here, I would also re-check after 1 week/100 mi.
Old Jun 22, 2007 | 02:39 PM
Oldvetter's Avatar
Oldvetter
100 ft-lbs, but don't forget to re-torque after driving 25-50 miles.
To Lug nut toruqe?
