Stereo Question
Old Jun 21, 2007 | 10:56 PM
Bills96TA's Avatar
Bills96TA
Default Stereo Question
When I bought my 99 FRC it had the Cassette stereo in it. The owner also had a CD unit he ordered years ago but never installed he gave me. It was used but was checked out and sealed in vacuum bag and still in the box when he gave it to me. When I installed the stereo everything appeared to work but there was no sound out of the speakers. Was I missing something, is the cassette system so basic it doesn't have the correct wires? The back of the Cassette unit has one plug in which matches a corresponding plug on the CD unit but the CD unit has another plug in it also that I didn't use as I had no matching harness on the car.
Thanks for any help
Old Jun 21, 2007 | 10:58 PM
Corvette Don's Avatar
Corvette Don
Thanks for any help
Is the CD player unit new or used?? Could be a bad unit if its used or in a rare case even if its new! But I would think it should work fine...
Old Jun 21, 2007 | 11:00 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Take it too a good audio shop like Best Buy, etc. They will have the right harness on the shelf and will hook u up in minutes for next to nothing!
Old Jun 21, 2007 | 11:01 PM
Bills96TA's Avatar
Bills96TA
It is used but was bought from a reputable vendor on here and was checked out ahead of time but it coulf very well be bad. I will swap it out with the unit in my TransAm next and see if it works in there as they appear to be the same.
I just wanted to make sure there wasn't some strange difference with the wiring on the base systems. I am a talk radio guy anyway so its not like I am really missing anything .
Old Jun 22, 2007 | 12:04 AM
BanditDude's Avatar
BanditDude
A vette factory radio should definitely swap in. I'm not sure the TA swap will work either. I'm fairly certain that the vette head unit is line-level outputs while the TA unit output is speaker-level (amplified). I may be wrong, though.
You might want to try posting your problem in the audio section. Good luck.
Old Jun 22, 2007 | 07:41 AM
VETTE47's Avatar
VETTE47
You Need The Adapter To Bypass The Bose Speaker Amps. Try The Soundgate By-pass Unit It Works Well. Any Car Stereo Shop Should Have It.
Old Jun 22, 2007 | 07:50 AM
oaks99's Avatar
oaks99
if you are talking about the 12 disc changer in the trunk area , i would think it would be plug and play .
oak
Old Jun 22, 2007 | 08:27 AM
sneakelman's Avatar
sneakelman
St. Jude Donor '08-'09
Thanks for any help
Couple key pieces of info missing. Is it OEM AC DELCO or another brand? Are both the old and new units BOSE? If the old one is and the new one isn't(and vice-versa), then you will get no sound. BOSE speakers have to have BOSE head units(or the adapters as another stated here) or they won't work.
Old Jun 22, 2007 | 09:24 AM
Bills96TA's Avatar
Bills96TA
All factory and non Bose (both units and speakers), I would have stated that if they were .
Old Jun 22, 2007 | 09:45 PM
sneakelman's Avatar
sneakelman
Plug the cassette back in, if you have sound, then you know the CD unit is defective. BOTH stock, BOTH non-Bose, it should just be a plug and go. Hope you get it right soon. Cruisin' around without tunes? Unless of course you have a sweet exhaust, then it's just a matter of keeping the RPM's up to make your own music.
Old Jun 22, 2007 | 10:34 PM
Drav1212's Avatar
Drav1212
Cassette ?????? CD ?????? what are those?????
This is 2007 folks get with it. You might as well put an 8-track in too, why don't you???
Old Jun 22, 2007 | 11:45 PM
Bills96TA's Avatar
Bills96TA
You know you are so right, in my TA or the GTO I never even turn the radio on, I love the sound of the car. I can honestly say that the radio in my TA has been on less than 10hrs and I have had the car since 99.
I did put the Cassette back in and its working fine so I am not real worried about it, as I said I am a talk radio/XM guy.
As for the CD-Cassette being old school, I don't even think I own one of either, my wife does though .
Old Jun 23, 2007 | 09:04 PM
sneakelman's Avatar
sneakelman
Limewire- free
CD burner-free(with laptop)
Having the songs I want, when I want them- PRICELESS
Old Jun 25, 2007 | 02:50 PM
Drav1212's Avatar
Drav1212
time to get rid of the OLD wife and get a new YOUNG wife
Old Jun 25, 2007 | 02:51 PM
Drav1212's Avatar
Drav1212
I have 3,000 songs on my IPOD, when you come up with a CD that can hold that many songs let me know.
Old Jun 25, 2007 | 07:50 PM
lionelhutz's Avatar
lionelhutz
Does the CD unit have a 9 pin and 4 pin connector on the left or drivers side? If so, then it is a Bose unit.
The Bose CD will also have 2 plugs ganged together on the right side or passenger side of it. This will be a 2-row with 10 pins per row.
The 2 left side connectors are line in and out's. I believe you can jumper the out's to the in's so that it works without the Bose processor.
I just had mine out to look to prepare for a stereo swap and I don't recall seeing anything Bose on the radio itself.
Peter
To Stereo Question
