Turn Signals Going Crazy
Old Jun 24, 2007 | 02:00 PM
jnfigueroa's Avatar
jnfigueroa
Default Turn Signals Going Crazy
OK...I know there are probably lot's of threads out there about this...but I'm still not sure what my problem is.
My turn signals are starting to act weird. There are times when they are working normal than after awhile they start to speed up and even sometimes they will speed up very...very fast then right away they go back to normal. I checked all the bulbs and all are working properly. Could it be my switch (4 way) or my turn signal arm?
Old Jun 24, 2007 | 02:02 PM
VinnyT's Avatar
VinnyT
Sounds like a ground wire. Do both sides do this or just one side?
Old Jun 24, 2007 | 02:11 PM
jnfigueroa's Avatar
jnfigueroa
both sides....even when I turn on the hazards...
Old Jun 24, 2007 | 02:18 PM
VinnyT's Avatar
VinnyT
I think it is a ground wire somewhere. Any corrosion in any of the bulb sockets?
Old Jun 25, 2007 | 02:18 PM
jnfigueroa's Avatar
jnfigueroa
i checked the rear lights and all seems to be fine...no corrosion. I checked the wiring and all is normal.
Old Jun 25, 2007 | 02:24 PM
VinnyT's Avatar
VinnyT
In that case, it sounds like the switch in the steering cloumn.
Old Jun 25, 2007 | 04:33 PM
cam99's Avatar
cam99
Default Codes
1. Check for Codes
2. Check Splice Block on Passenger side in Engine Compartment. Remove/inspect/sand where it mates to the frame. ( http://forums.corvetteforum.com/showthread.php?t=896875) G102
Does the Relay's sound like they are going crazy in the footwell of the Passenger compartment?
Old Jun 25, 2007 | 05:02 PM
OleStraightStick's Avatar
OleStraightStick
St. Jude Donor '08
i'm no pro but could it be the hazard module? mine is a 2000 and somebody said the older c5 turn signals operate through the hazard module.. every so often my signals dont work so i press the hazard button once and all goes to normal... maybe yours is fried.. just a thought.. goodluck though!
Old Jun 25, 2007 | 06:17 PM
2001c55's Avatar
2001c55
8th Gear
i had turn signal problems, changed the hazard sw, problem solved.
Old Jun 26, 2007 | 02:30 PM
jnfigueroa's Avatar
jnfigueroa
thanks to all. I'll be working on it this weekend. thanks for the advise.
To Turn Signals Going Crazy
