Trunk on Convertible
Old Jun 25, 2007 | 02:12 PM
Borracho's Avatar
Borracho
Default Trunk on Convertible
I just purchased a convertible C-5 and was wondering if opening the trunk was a common problem. The trunk lid pops open but I can not pull it open unless I wedge a key or a screw driver in between the trunk lid and the bumper cover.
Any suggestions??
Old Jun 25, 2007 | 02:18 PM
GS Ron's Avatar
GS Ron
Any suggestions??
Try lubing the trunk hinges...........That don't work.
Your trunk shocks are probably wore out...........
Old Jun 25, 2007 | 02:22 PM
bilx013's Avatar
bilx013
St. Jude Donor '12
Mine's a little rough as well at times....I am able to get a pinky under it though...
rws.1's Avatar
rws.1
or you can buy one of these...
c5trunkpopper
Old Jun 25, 2007 | 02:23 PM
MR.WaynesWorld's Avatar
MR.WaynesWorld
From: The real question is; When you turn your car on, does it return the favor..
Cruise-In VIII & IX Veteran
St. Jude Donor '07-'08
Mine does the same thing. But I can just about get my finger under it. One thing I did find out if you pop the trunk and then close the door (that is when the top and windows are up) the lid pops up a whole lot.... Haven't tried it with the top down....
Old Jun 25, 2007 | 02:25 PM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
Very common; every few months I spray WD-40 on it and it seems to work better.
Old Jun 25, 2007 | 02:30 PM
MR.WaynesWorld
Is there a spring that can be changed to a stonger one so the lid will pop up more?
Old Jun 25, 2007 | 02:34 PM
Borracho's Avatar
Borracho
thanks! for all your suggestions
Old Jun 25, 2007 | 04:38 PM
gincledon's Avatar
gincledon
[QUOTE=rws.1;1560820591]or you can buy one of these...
QUOTE]
Just ordered one. This has been a problem as long as I owned the car. Thank You.
Old Jun 25, 2007 | 07:28 PM
KARLDDS82's Avatar
KARLDDS82
I put one of these on my 2002 convertible. clever and great product.I highly recommend it.
Old Jun 25, 2007 | 07:32 PM
Tino's Avatar
Tino
Nice invention, how much harder is it to close the lid?
Old Jun 25, 2007 | 09:38 PM
Rodster21's Avatar
Rodster21
if the top and windows are up, just push the trunk release on your fob and then open and close one of the doors. works for me
Old Jun 25, 2007 | 09:54 PM
Luv My Vette's Avatar
Luv My Vette
I don't have this problem yet..... It is a bit hard to close it though, I might be a little too gentle with it
Old Jun 25, 2007 | 09:56 PM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default Same here
When I bought mine from the dealer pre-owned they replaced the shock struts and it barely helped. I can still get a pinky under there too. I agree with the other posters here with the driver's door manuever with the windows and top up. Sort of hinky but it does work! Happy Trails anyway!
Old Jun 25, 2007 | 10:30 PM
Kudzu's Avatar
Kudzu
St. Jude Donor '04-'05-'06-'08-'09
this completely solved my trunk lid problem at a fraction of the cost of some of the other mechanical solutions and I don't even notice it when I open the lid. Even if I have to buy another one down the road, I am still $ ahead.
Old Jun 25, 2007 | 11:13 PM
ToplessBlonde's Avatar
ToplessBlonde
Old Jun 25, 2007 | 11:37 PM
TexasMadMan's Avatar
TexasMadMan
Thanks for the tip.
To Trunk on Convertible
Old Jun 25, 2007 | 11:54 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
I just ordered the C-5 truck popper. I have the same problem on my '02 roadster. I have used the WD-40 method but that only gives temporary relief.
Old Jun 26, 2007 | 12:39 AM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
If you do a search in the archives you will see a TSB that discusses the weak spring in the latch of Verts and FRCs and talks of an adjustment/Mod that helps the latch open, pushing the striker/deck lid up. I also wanted to blame the shocks (gas struts) but they are NOT the problem.
Old Jun 26, 2007 | 12:43 AM
rws.1's Avatar
rws.1
to close my trunk since the installation of the C5 trunk popper I just put my hand on the trunk lid and lean on it until it latches.
