Trunk on Convertible
Old Jun 26, 2007 | 07:14 AM
DeeGee's Avatar
DeeGee
Originally Posted by DavzC5
Very common; every few months I spray WD-40 on it and it seems to work better.
Spray the lock mechanism and it'll pop up a little better. Also you'll find the rubber buffers on the trunk lid actually turn and extend slightly. If you wind them out a little it gives more push as the trunk pops.
The other method is to pop the trunk and then close the door. The air pressure pushes the lid up.
Old Jun 26, 2007 | 08:15 AM
bonnell's Avatar
bonnell
Originally Posted by MR.WaynesWorld
Mine does the same thing. But I can just about get my finger under it. One thing I did find out if you pop the trunk and then close the door (that is when the top and windows are up) the lid pops up a whole lot.... Haven't tried it with the top down....
Old Jun 26, 2007 | 09:00 AM
billrush's Avatar
billrush
I have seen an easy fix. One of our club members added a small coil spring beside the latch. His pops up quite nicely
Old Jun 26, 2007 | 10:00 AM
Phanni's Avatar
Phanni
Buy the truink popper and the problem is gone forever.
Old Jun 26, 2007 | 10:30 AM
dajora03's Avatar
dajora03
St. Jude Donor '07-'08-'09-'10-'11-12-'13-'14-'15-'16-'17
Trunk Popper works great.
Old Jun 26, 2007 | 12:01 PM
UKXPAT's Avatar
UKXPAT
Originally Posted by rws.1
I put one of these on my 2002 convertible. clever and great product.I highly recommend it.
me too, this thing is excellent!
Old Jun 26, 2007 | 12:03 PM
67weaver's Avatar
67weaver
Originally Posted by bilx013
Mine's a little rough as well at times....I am able to get a pinky under it though...
Same here but it gets annoying
or you can buy one of these...
c5trunkpopper
From what Ive heard this is they way to go... I dont know why I havn't gotten one yet
Old Jun 26, 2007 | 12:37 PM
78-Bandit's Avatar
78-Bandit
Active Streak: 90 Days
The trunk popper is the best $12 you can spend
Old Jun 26, 2007 | 01:01 PM
chai1836's Avatar
chai1836
I WD-40'd the bejeebus out of the latch mechanism and hinges and have not had a problem since
Old Jun 26, 2007 | 01:50 PM
dndrsn's Avatar
dndrsn
BTDT
Old Jun 26, 2007 | 05:40 PM
BanditDude's Avatar
BanditDude
I saw that too, and purchased an assortment of small springs from Lowes for ~$3. It isn't perfect, but it helped considerably.
Old Jun 26, 2007 | 07:38 PM
trobert's Avatar
trobert
Cruising
Had the same problem. But my fix is different from anything I've read here. My stricker was loose, had to pull the backup light off the rear bumper to reach the striker nuts and retighten. Mine were so loose two of the nuts fell off and I found them inside the bumper. It works like new now!!!!!!
Old Aug 21, 2007 | 06:23 PM
  #33
mkenyon's Avatar
mkenyon
I just made a home made version of the trunk popper using a spring from the center section of the winding mechanism from a yard trimmer. Bent the end and stuck it on with the screw at the latch.
It is not as elegant as the trunk popper, but it works for now. We'll see if it holds up to the test of time. Folks here LOVE the trunk popper and I just happen to come across this spring in my garage and thought I'd give it a try.
Old Aug 21, 2007 | 06:39 PM
  #34
gpz's Avatar
gpz
i have the same problem..i just can get my finger under it to open..i just deal with it..
