Do I need to replace Them? I am getting a message every time I drive that the left front tire is flat. The tire reads 30 psi cold. They are now 6.5 yrs old as original. Thanks.
Do you still have run flats? If so then you need to check your tire and make sure its not flat. Usually if you need to replace your TPS then you will get a message saying "Service Tire Mon. Sys." or something alone those lines.
I'm not sure which sensors the vettes use, but some are battery powered so I would think that after 6-7 years the battery may be dead, may be worth checking into as an alternative to buying a new sensor, assuming that the battery can be changed?
I dont think the batteries can be replaced.
To the OP, contact Gene Culley at www.gmpartshouse.com, he can probably get you the best deal on new sensors.
