I think the exhaust would be in your way, and I doubt the wires would fall far enough for you to easily replace the bulbs from below. It's extremely easy to pop out the lens. What's your hesitation?
2 screws for each taillight and they're out. Can't get too much easier than that, unless you have spaghetti arms and can wiggle them behind the bumper.
I installed tail light seals a couple weeks ago. I noticed that the tail lights are screwed into the plastic bumper. Im worried that if they are taken out to much it will strip the plastic bumper thread.
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
If you remove one on each side - it's simple matter of reaching into the hole to get to the other one. Personally - I was was replacing an incandescent bulb - I would make the assumption that they were all the same age, and if one is burned out - the others are close behind. Replace all four.
Rob
use a HAND screw driver and not an electric. GO slow, dont over tighten. Simple.
