Irun4cops Project Car
Pictures will come in time, and be added to posts as I do the upgrades.
Heres what I started with...
http://www.vettepieces.com/customer_...5/Koppels.html
566 wrhp 02 black/black z06 d1sc 12 rib supercharged intercooled water/alc injection 383 lunati forged bottom 2.73 gears with m12 6speed.
NEW PICS ADDED:
http://s277.photobucket.com/albums/kk51/irun4cops/
Im interested in the usuall contenders. 6 piston brembos, stop techs, and baers. I dont want a dilled rotor, probably only slotted to avoid cracking.
However, im gaining interest in these titanium ceramic coated rotors from red devil brakes. Warping and excessive heat seem to be a non issue. Interestingly, the break in calls for harsh high speed stops. Read more about it here:
http://www.reddevilbrakes.com/page/page/898389.htm
and
http://www.reddevilbrakes.com/page/page/884994.htm
***I ended up just going with some stoptech slotted rotors for now... its hard to fit upgraded brakes under the stock front wheels. Drilled rotors crack on us guys who slow down from 180+... you can see my 4 month old drilled and slotted rotors cracked everywhere after less than 5k miles put on them.
Cameras are switching from dv tape to recording straight to hard drive. I im trying to figure out a way to have cameras, (at least 2 HD) that fire forward, backward, and one for inside the car for guages. My plan is to edit between these 3 footages, and create high quality HD edits of racing.
The system will be constructed so that a single button can be pressed, and all 3 cameras start recording at the same time. Hard drives set up in raid0 will be in the trunk, capable of capturing huge valumes of data. When I get home, ill be able to dump the footage to a hame based computer, and wipe the slate clean for more space to record fresh footage.
The quality of cameras I want to use will be the expensive part, therefor I dont plan on buying them, instead I will be renting them. My car will have braces, and permanent mounts for these cameras so that I can attach them. The wires will remain in place at all times.
Idealy, I will be able to gather footage of my car and other cars in action, and be a camera vehicle capable of keeping up.
***a buddy of mine just purchased the most expensive digitial camera in the world i guess... its called THE RED camera. It can make movie quality digital movies, 4xhd quality. He wants to use my car as a mule to get footage, and i might put some of my need for speed to good use, and help him make movies for hollywood. Ive also talked to him about just being the official camera car for gumball events and other high speed activities.
Either way, I plan on installing at least 2 compact hd cameras such as the one pictured below. One camera will be put BETWEEN the exhuast tips, in the middle, behind the diff... with a heat shield around it of course. The other will be put up in the left or right front corner of the car. Both will be on remote activate for recording. These cameras hold 8-20 hours of HD footage.
***I ended up finding a trans and rear end that were COMPLETELY BUILT with all chryo treated and micropolished UNITRAX gears and micropolished shafts. Upgraded keys, carbon fiver, synchros, etc. The rear end came complete with the dte hardened output shafts on both sides. I sold my old z06 trans and put it in a rubbermade tub and shipped it to cali, and got a built c5 trans from orange county trans in cali who completely built this trans with every possible upgrade. My new setup has the higher gearing of the stock vette trans, but the lower rear end gearing of 3.15, so it comes out to be the same as before almost as before. I still have the TALL 2.73 rear diff for sale if anyone wants it.
Reason for extra fuel is for gumball and cannonball runs around the US. Going 200mph is pointless when you have to stop and fill up all the time.
*** I ended up going with 1000cc/96lb low impedance injectors. I have upgraded high flow fuel rails. I dont have the extra fuel tank yet, but if i did, i think i would put it above the beam in the *** end of the car, right behind the tail lights. Disadvantage is top heavy weight added... thus im waiting.
***the old fuel system was a joke, after driving for about a half hour, the car would go lean... this is because the fuel pumps would heat up and cavitate. I invented my own fuel system... i use DUAL tt supra denso pumps in BOTH tanks. This supplies over 1000hp worth of fuel. I have dual braied lines going up, passing through custom fuel coolers that are mounted in the left nose of the car, and then up to the upgraded rails, 1000cc injectors, and back through a 2000hp capable aeromotive regulator set to 45 psi and is boost relative, and then back another an-10 line that comes back through ANOTHER fuel cooler, and is then split beween the 2 tanks. The 2 tanks are now connected with a slosh line located at bottom tank level, that keeps the 2 tanks at equal fuel level. We fabbed up a custom guard that protects the braided slosh line from debris from the road to prevent leaks or breakage.
Whatever you do dont take any styling cues from any of the other customer rides on that site, f*cking yuck
if you are talking about doing this on the street, this thread needs to be shut down.......
I got the best loooking car they've ever built, theres not contest there
