replacing tire sensor nuts??? is it tricky??
Old Jun 30, 2007 | 04:23 PM
cyoul8rnj's Avatar
cyoul8rnj
St. Jude Donor '08-'10-'12
Default replacing tire sensor nuts??? is it tricky??
purchased chrome replacement and wondering if it is going to be difficult to replace without losing something into the wheel or air pressure, talked to a few car guys not vette guys and they tell me take it to Firestone and let them do it, I can't find someone who knows how to do it.
Old Jun 30, 2007 | 04:31 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
I Just Loosened Them One At A Time And Replaced Them . I Think The Air Pressure Hold Them Up ???? Had No Problems The First Tire I Jacked Off The Ground But The Rest I Did Not....PUT SO LOCK TITE ON THEM THE REPLACEABLE ONE MINE CAME LOOSE AFTER A WHILE ......
Old Jun 30, 2007 | 05:33 PM
JoesC5's Avatar
JoesC5
Loosen the cap until only a couple of threads hold it on. Unscrew the nut until it just touches the cap and then take a wire tie wrap (like used on a loaf of bread) and tie it around the valvestem between the wheel and the nut. Remove the cap and nut and put on the new nut. Remove the wire tie wrap and then tighten the nut, Replace the cap.
Replace lost air.
Old Jun 30, 2007 | 05:40 PM
wamara's Avatar
wamara
Cruise-In II Veteran
No, it's just a nut!! Just don't push or let the valve stem drop into the tire - then you'll be
Old Jun 30, 2007 | 05:57 PM
csexton's Avatar
csexton
Replace lost air.
Chuck
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
PMed you.
Old Jun 30, 2007 | 10:52 PM
Great info. Was wondering if there was a way to do this without breaking the tire down.
To replacing tire sensor nuts??? is it tricky??
