Please, if anyone has a stock radio/cd in their garage/shed, or where, can you please measure the size of the front plate on it.
I want height, and I want width.
Also bolt holes from center to center.
Inches or millimeters will do.
Thanks in advance
I've measured the face plate. The actual box is a few mm smaller
Height: 92mm
Width: 207mm
Bolt holes from center to center: 231mm
The last is difficult to measure accurately because the brackets are set back from the face
Height: 92mm
Width: 207mm
Thanks DeeGee for comming up with the dimension answers.
I will order the iso conversion lead from Halfords on Monday, and see if it works, they say it does, but you never know.
