Water Wetter DOES work..
Old Jul 6, 2007 | 01:03 PM
VinnyT's Avatar
VinnyT
Default Water Wetter DOES work..
Poured a bottle in this morning. Normally in stop and go traffic, it will reach 220. With WaterWetter, it did not go above 210. Just a 10 degree drop, but any little cooling helps. Great $7.00 mod!
BTW, it is a stock motor with 50/50 Dexcool/water.
Old Jul 6, 2007 | 01:10 PM
rayncris's Avatar
rayncris
Nice to hear Vinny. I'll have to try that. Thanks.
Old Jul 6, 2007 | 01:32 PM
edensknight's Avatar
edensknight
Highly recommend Water Wetter by Redline for any automotive engine coolant system. And, I have been using Redline products with satisfaction for over twenty years! Good ****!
Old Jul 6, 2007 | 01:55 PM
Good to hear that it works.
Old Jul 6, 2007 | 02:37 PM
jnfigueroa's Avatar
jnfigueroa
Poured in some a couple of days ago here in sunny phoenix az....haven't seen too much difference...but i'll give it a chance for another few days....cause it has only been about 115-117 the past couple of days!!!!
Old Jul 6, 2007 | 02:40 PM
sailohio's Avatar
sailohio
Old Jul 6, 2007 | 02:50 PM
jvette2's Avatar
jvette2
I have used Water Wetter for years in my C-3 and did see at least
a 10 degree difference but I never even thought about using it in
the C-5. After reading your post I am getting some for the C-5.
Old Jul 6, 2007 | 03:02 PM
MUKAK's Avatar
MUKAK
water wetter works good but a lower Tstat works better!!
i have a 170 Tstat in my 97 and my water temp is around 185-195 during hottest summer days and that just with DEXCOOL
i tried WATER WETTER and it didnt do anything to the WATER TEMP... but then again i have a 170 degree TSTAT
Old Jul 6, 2007 | 04:27 PM
rws.1's Avatar
rws.1
I have used Redline water wetter and Royal Purple Purple ice in my Vetttes for the past 3 years.
The technology is well understood. a surfactant helps the water "wet out" (make more intimate contact with) the radiator fins and permits a higher rate of heat transfer.
Old Jul 6, 2007 | 05:35 PM
davesbedroom's Avatar
davesbedroom
I forgot where I heard this, but does the C5 need two bottles of water wetter?
Old Jul 6, 2007 | 06:23 PM
hotwheels57's Avatar
hotwheels57
I've used it for years in all kinds of hot rods, mostly carburetor tri five Chevy cars with crate engines. It does stabilize the temperatures in dry hot AZ summer temperatures.
...the water "wet out" (make more intimate contact with) the radiator fins...
...if your coolant is making "more intimate contact with the radiator fins", you've got a leak!
Old Jul 6, 2007 | 06:30 PM
RaceSmith's Avatar
RaceSmith
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '07
I use that in my KX250... I had no idea you could use it in the vette. Did you change your Dexcool and then add the WW or just you top it off?
Old Jul 6, 2007 | 06:43 PM
2000BSME's Avatar
2000BSME
didn't do **** for me.
Old Jul 6, 2007 | 07:01 PM
VinnyT's Avatar
VinnyT
Just poured the bottle in.
Old Jul 6, 2007 | 07:06 PM
Tigershark3's Avatar
Tigershark3
I've seen where people have put in 2 bottles but the label on the bottle says 1 bottle per 12 quarts which is about what our is. I've got some in my car - car will still run 190 with a 190 stat but it does not seem to get as hot as before - maybe 5-8 degrees cooler so to me it was worth it. Corvette Enthusiast article a while back did a study on the stuff. With 50/50 dexcool and distilled water w/ the water wetter they saw about an 8 degree improvement. $.02 deposited.
Old Jul 6, 2007 | 10:51 PM
gpracer1's Avatar
gpracer1
People, no matter how cool it is outside or how big your radiator or fans are or how much water wetter you use, your car is never going to be cooler than the thermostat rating.
So if your stock thermostat car is at 197 on the freeway going 70 mph, it wont change more than maybe 2 degrees with water wetter. However, if you are cruising and your temps are 210 at 70 mph, then you might see a 5-10 degree difference by adding WW. And in a BONE STOCK car, the temps in traffic will still get up to 225 because the fans are not on. But with water wetter, when the fans do come on, the temp will fall much faster.
Old Jul 6, 2007 | 10:56 PM
fastvett's Avatar
fastvett
IT worked good for me. worth the money.
To Water Wetter DOES work..
Old Jul 6, 2007 | 10:57 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Sprint guys have run Watter Wetter for a long long time.
It work really good in Race Car Applications. The higher percentage of water in the mix, the better it works.
Obviously it works best when just mixed with straight water.
Peace
Chip
__________________
..................Click for
Old Jul 6, 2007 | 11:17 PM
gpracer1's Avatar
gpracer1
Used it in all my superbikes since 95. Water wetter and water only. Even in Phoenix and Vegas heat at the track, it works great.
Old Jul 6, 2007 | 11:43 PM
WetteVette's Avatar
WetteVette
Thanks for the excellent explanation. Put some in my car today. Outside temp around 110, A/C on. First, made a test run on the freeway and a little stop and go. Then added the WW. At 65 to 70 MPH, coolant temp around 196 degrees. Same as before adding WW. Stop and go around 210, same as before adding WW. Now I know why.
